Please forgive me ahead of time if I ask a stupid question. I'm not exactly a computer guru.
Anyways, I have the following power supply:
EVGA SuperNOVA 750 G2 220-G2-0750-XR 80+ GOLD 750WOn the cable that runs to my hard drive, two of the wires that go into the large clip the plastic coating has worn away somehow and the bare wires are exposed. There are 2 other clips on the cable and I was wondering if they were all the same size?
Another question, will these clips also fit into a Solid State Drive or do I need some type of adapter to connect it?
Thanks for your help!
