Re: Power spikes/requirements for a 3070 FTW3 ultra
2021/09/25 09:31:19
The 850w is more then enough, a 3070 such as the FTW3 Utlra, when running at or near 100% load will spend most of its time pulling ~240-270w. If you wanted it to run cooler, you can just set it to 1800mhz and 825mv on the boost curve and from what I've observed with 20 different 3000 series, is that you should expect it to run around 160-180w like that.
However the 850 is MORE then enough. I'm running my 3090 on one.
