Shift209
Tried uninstalling and reinstalling drivers using DDU, along with reinstalling Precision X OC. Help would be appreciated
Valtrius Malleus
Re: Power Temp and Memory Temp not displaying in Precision. 1070 FTW
2017/09/12 06:51:55
I don't believe the FTW gets the additional sensors. I think that's on the FTW2 and a few others but not the FTW.
bigboy1
2017/09/12 07:33:57
They dont display on the FTW,but do on the FTW2.
bdary
- Ribbons : 116
2017/09/12 07:35:32
☄ Helpfulby XrayMan 2017/09/12 21:17:13
Shift209
2017/09/12 07:37:10
Oh geez, thanks for the heads up! The blank spaces made me think something was off.
Appreciate the clarification from you 2
Valtrius Malleus
2017/09/13 00:40:06
Yeah I'm not big on the extra spaces either. The first Precision I used didn't have those temps showing and then an update changed it all. I would prefer if they only displayed when using a relevant card, like K-boost, fan slider or even the sensors button.
thesilverguild
2018/04/29 15:10:32
Just to double check but the 1070ti SC Black Edition does not have the Power & Memory Temp sensors right?
Callud
2018/05/21 10:08:07
I have the same problem and now im not sure if my card "EVGA GeForce GTX FTW HYBRID" doesnt have those sensors??? I couldnt find any information via google or evga data sheed to my card. Can someone clarify please?
bdary
- Ribbons : 116
2018/05/21 10:38:51
Callud I have the same problem and now im not sure if my card "EVGA GeForce GTX FTW HYBRID" doesnt have those sensors??? I couldnt find any information via google or evga data sheed to my card. Can someone clarify please?
Clarifying which Hybrid GPU you have would help other members answer your question. Is it a 1080, 1080Ti, 1070Ti, etc...??
Callud
2018/05/21 13:06:21
Oh yes sorry for forgetting that... i got a EVGA GeForce GTX 1080 FTW HYBRID. Thanks for your help in advance! Really appreciate it.. im very confused. Also the On screen display doesnt work in games or other applications. Very disappointing.. :(
post edited by Callud - 2018/05/21 16:15:40
- Ribbons : 270
2018/05/21 21:34:56
Correct. If it doesn't advertise iCX or 9 thermal sensors, it doesn't have those sensors. It would need to be a FTW3 Hybrid to have those sensors, not "just" a FTW Hybrid. Also the On screen display doesnt work in games or other applications. Very disappointing.. :(
Uninstall EVGA Precision and install MSI Afterburner instead. You will be less disappointed.
post edited by ty_ger07 - 2018/05/21 21:36:58
Callud
2018/05/22 05:32:48
