Power Supply Possibly Going Out.
ParzivalsDen
2021/09/13 16:24:17 (permalink)
650 Watt BQ is like buzzing and ticking idle and under load mostly under load when gaming. Or doing some tasks, also it can’t be the fan because it doesn’t sounds like a fan being blocked (if you get my drift) By anything I cleared out the debris under and all around the case (Dust) and when I powered it on it still does the same thing. Ticking and buzzing idle and under load.
3 Replies Related Threads
    • Ribbons : 198
    Re: Power Supply Possibly Going Out. 2021/09/13 20:21:14 (permalink)
    Probably best to just send it in to have it replaced.
    Want to save 5 to 10% on your next EVGA purchase? Just click on the associates banner to save, or enter the associates code at checkout on your next purchase. If you choose to use my code I want to personally say "Thank You" for using it.
    ParzivalsDen
    Re: Power Supply Possibly Going Out. 2021/09/14 19:37:59 (permalink)
    Yeah man I went out to micro center and got a new one I was like too me that’s a ticking time bomb that could go off any second in my house.
    • Ribbons : 198
    Re: Power Supply Possibly Going Out. 2021/09/14 19:42:40 (permalink)
