Power Supply Cables
Bauerrpc
2022/04/27 01:30:03 (permalink)
I am in need of cables for my supernova 1000 P power supply. I found 100-G2-06KO-B9 on the evga eu website but cannot purchase through them. I found the same cables on amazon for twice the price, which almost makes it worth buying a donor power supply for the cables.
Is it possible to purchase from the eu store or do i need to explore other options.
5 Replies Related Threads
    Jomama22
    • Ribbons : 19
    Re: Power Supply Cables 2022/04/27 07:26:25 (permalink)
    You may be able to contact support to send it is at all possible but if it's not purchasable through the store, then you may have to go through 3rd parties unfortunately.
    My associates code for discount at checkout: LXBKILTLID8VHVK
    <a href="https://www.evga.com/asso...8VHVK"><img src="https://www.evga.com/badg...ng"></a>
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: Power Supply Cables 2022/04/27 07:27:55 (permalink)
    Where are you located OP?
    Bauerrpc
    Re: Power Supply Cables 2022/04/28 02:24:58 (permalink)
    Currently in Germany,  I will contact the support to see if they can help me.
    Wallx
    Re: Power Supply Cables 2022/04/29 14:18:48 (permalink)
    Is it important to use the PSU's own power cables?
    EVGATech_AnthonyS
    EVGA Tech Support
    Re: Power Supply Cables 2022/04/29 15:27:35 (permalink)
    @Wallx This is important if you are moving from brand to brand or model to model. We have some of our models that have interchangeable cables, which you can find cable compatibility HERE.
    Like our service? Please provide feedback for us at the link HERE
