Power Supply Cable Interchangeability
Ganeen
2020/12/06 14:29:39 (permalink)
I know that you should almost never interchange power supply cables from different companies due to the risk of damaging components, but with that in mind I have looked up the cable layouts for EVGA and Corsair and have a question.
Attached is an EVGA and a Corsair PCI-Express power supply cable. They seem to be identical except for on the PSU side there is an 5th ground on the EVGA while the Corsair has a blank cable that appears to do nothing.
My question is, would it be dangerous to have an extra ground? I bought the 12 pin $40 cable from EVGA (left configuration) and I want to be able to use it. My power supply is from Corsair. (HX850i)
This is the cable in question:
Thanks guys!
1 Reply Related Threads
    JDauwalter
    Re: Power Supply Cable Interchangeability 2020/12/06 14:38:39 (permalink)
    They aren't dangerous to hook up, but they simply don't work. There's a safety mechanism in there that doesn't trigger and makes the cord unusable. I know because I tried this by plugging a Corsair cable into an EVGA PSU and it provided no power.
