Re: Overclocking air vs. water (aio)
2021/10/18 10:28:36
your question is very vague but I will try to give you an answer anyway.
Liquid cooling, in addition to being more powerful, is also more efficient, but you only start to appreciate the difference when you push the gpu temperature with the OC (very likely if you are a miner, unlikely if you are a gamer)
