Re: Nu Audio Pro High Res Audio Mode Missing?
2020/03/16 00:16:25
Please don't bump. It's against the forum rules.
With regards to your question, since you have the Pro card only, and not the 7.1, there is no need to run a separate Hi-Res mode. You already have access to sample rates higher than 192kHz. All the Hi-Res Mode does when using the Pro 7.1 cards is switch the card into 2-Channel mode to enable access to sample rates higher than 192kHz.
