Re: Not sure if I'm using the correct plug from Power Supply to GPU
2022/08/06 21:00:39
Yes you want to use the cable that has PCI-E 6+2 pins.
The cable is directional, the end with 6+2 goes into the GPU, the other end into the PSU.
