ItsWolfee
Well I was looking at graphic cards recently and picked up a EVGA 1080 Ti sc2 and coming from 1060 6gb im getting the same fps it feels like on csgo and fortnite. MY gpu runs at 20-22% Usage And cpu 10-12% usage and only getting 120 to 170 fps sometimes with everything set to low. Just seems a little off. I downloaded and did a clean install for the driver. My setup is a Ryzen 2700x 16gb ram 3000hz and the 1080 ti.
- Ribbons : 135
Re: Not happy with 1080 Ti fps
2019/05/15 21:26:54
ItsWolfee Well I was looking at graphic cards recently and picked up a EVGA 1080 Ti sc2 and coming from 1060 6gb im getting the same fps it feels like on csgo and fortnite. MY gpu runs at 20-22% Usage And cpu 10-12% usage and only getting 120 to 170 fps sometimes with everything set to low. Just seems a little off. I downloaded and did a clean install for the driver. My setup is a Ryzen 2700x 16gb ram 3000hz and the 1080 ti.
How about a few more details? Your resolution would be helpful. If you're running at 1080p or less, you're not going to see much change as you're barely loading the GPU and GPU Boost 3.0 is probably capping your utilization. More than likely setting Prefer Max Perf, in the game profile would get you a bit higher usage...but...I've no idea what your expectations are or exactly what settings you're using. The lack of information, leaves us guessing. Fill us in.
ItsWolfee
2019/05/15 21:47:56
Sorry about that well it’s 1080p 144 hz and my expectations just thought they would be a little bit higher FPS that from a 1060 6gb. I have max settings and see it go to 30% usage. Just feels weird that’s all.
- Ribbons : 135
2019/05/15 22:28:42
ItsWolfee Sorry about that well it’s 1080p 144 hz and my expectations just thought they would be a little bit higher FPS that from a 1060 6gb. I have max settings and see it go to 30% usage. Just feels weird that’s all.
Well, don't take this wrong...but an intel processor of BW-E or newer would gain you another 15% or so. But the main thing is you're under utilizing the GPU. You could also use DSR, effectively doubling the resolution. That would reduce jaggies and load the GPU more. What scores do you get for 3DMark? I was just playing Mass Effect 3, with ALOT HD texture mods, 4K resolution, and 2X SGSSAA or effectively 8K and I was hardly over 40% utilization and easily over 60 FPS.
Neutro
- Ribbons : 12
2019/05/15 23:31:48
9900k / EVGA Z370 FTW / 4070 FE / Corsair DDR4 3200 Mhz 16GB / Phanteks P600S / EVGA Supernova 1200 P2 / WD SN850 1 TB / Asus PG248Q - pix
DRY_ICE
2019/05/16 00:24:03
I would believe somethings off. I just ran CS:GO for reference and I get 250-300 fps average on Dust 2 and Office with 7700k, 32gb 3kram, and a 1080ti. That's at max settings as well.
ItsWolfee
2019/05/16 17:21:12
Well here is the score (9729) and said I had a invalid score. And it wont let me post the link... www .3dmark.com/ 7200610 Also after testing csgo with multicore rendering on my fps goes 220-almost 300 40% Gpu usage but when its turned off im at 90-140 max with gpu usage 29%( Also tells me dedicated gpu memory 1.7/11.0GB)
post edited by ItsWolfee - 2019/05/16 17:55:58
Neutro
- Ribbons : 12
2019/05/17 07:33:06
Why is your score invalid? 9729 seems ok for your card. If i remember correctly you wont get a link if the score is invalid. Post the screenshot of the result if you can, or send it to me by pm and i'll add it here :)
2019/05/17 08:24:13
ItsWolfee Well here is the score (9729) and said I had a invalid score. And it wont let me post the link... www .3dmark.com/ 7200610 Also after testing csgo with multicore rendering on my fps goes 220-almost 300 40% Gpu usage but when its turned off im at 90-140 max with gpu usage 29%( Also tells me dedicated gpu memory 1.7/11.0GB)
I got a 404 error when checking that Link ---> https://www.3dmark.com/7200610 What OS ?--- if Win 10 Which Version & Build number Which Nvidia Driver ? What have you changed in Nvidia Control Panel ? Have you set Windows to Performance Mode ?
- Ribbons : 135
2019/05/17 08:27:00
Here's the link kids https://www.3dmark.com/spy/7200610 Your result has the following problem(s):- Time measurement data not available. The validity of the result cannot be determined. (What is this?)
- SystemInfo scanning was not enabled for this benchmark run. Please enable SystemInfo from benchmark settings and re-run the benchmark. (What is this?)
- Processor is not recognized (What is this?)
- Graphics card is not recognized (What is this?)
- Graphics driver is not approved (What is this?)
Your scores look about right for a stock clocked 1080 Ti or a bit less than 10K GPU score. Cool GTX I got a 404 error when checking that Link ---> https://www.3dmark.com/7200610
You forgot the 'spy' part of the URL.
post edited by HeavyHemi - 2019/05/17 08:29:11
2019/05/17 08:29:13
Neutro
- Ribbons : 12
2019/05/17 11:07:30
Thanks :) Seems like the problem is that you used an outdated version of 3DMark. But the score seems right nonetheless.
DRY_ICE
2019/05/17 12:44:14
Hoggle
2019/05/17 12:52:12
What are the FPS in Fortnite with setting maxed out? Sometimes low quality settings don’t increase much from high quality if something besides the graphics card is holding the system back.
MadmanRB
2019/05/17 14:30:48
HeavyHemi Well, don't take this wrong...but an intel processor of BW-E or newer would gain you another 15% or so. But the main thing is you're under utilizing the GPU. You could also use DSR, effectively doubling the resolution. That would reduce jaggies and load the GPU more. What scores do you get for 3DMark? I was just playing Mass Effect 3, with ALOT HD texture mods, 4K resolution, and 2X SGSSAA or effectively 8K and I was hardly over 40% utilization and easily over 60 FPS.
I say the fault is indeed running 1080p with this GPU, the OP is basically holding the GPU back. Even if they had a Intel the results would be similar. Plus its not worth switching platforms for a mere 15% for 1080p but i get it 15% is like 999% to intel fanboys wearing beer goggles. Sure makes spending that extra $100 hurt more when the results are that small.
post edited by MadmanRB - 2019/05/17 14:35:10
AHowes
- Ribbons : 27
2019/05/17 21:34:55
Guess what people ain't saying is buy a new 1440 monitor! 144-165hz 1440 gsync monitor would do it. Or even a 32-34" 1440 ultra wide.
DRY_ICE
2019/05/17 23:07:56
Have a similar setup and it seems you're getting similar results as mine now. I don't know, I think it's pretty good performance. For me it just wansn't worth the absurd cost of the 20xx generation this time around. Very happy I got a 1080ti at launch for msrp and it's served me well. Don't have any games I play yet that I can't enjoy 1080p on a 144hz gsync monitor.
Vlada011
- Ribbons : 11
2019/05/18 01:02:05
I'm happy with GTX1080Ti fps... I'm not happy when I compare GTX1080Ti score with RTX2080Ti K|NG|N score. Than I'm not happy.
Exnetic
2019/05/18 02:04:51
A 1080Ti has no problem running all games at 1080P high quality from 144fps or more
MadmanRB
2019/05/18 02:56:22
AHowes Guess what people ain't saying is buy a new 1440 monitor! 144-165hz 1440 gsync monitor would do it. Or even a 32-34" 1440 ultra wide.
Meh dont really need gsync, freesync monitors will do. If you get one of the gsync compliant freesync monitors you are good to go. Besides if you have high enough refresh rate and a decent GPU to pair it with screen tearing is minimal, screen tearing is at its worst on 60hz while on 144hz and above its barely noticeable
ItsWolfee
2019/05/18 17:07:33
I do notice a little screen tearing on fortnite and pubg on the omen 144 monitor when I cap my fps to 144 it tears super bad.
MadmanRB
2019/05/18 22:14:44
ItsWolfee I do notice a little screen tearing on fortnite and pubg on the omen 144 monitor when I cap my fps to 144 it tears super bad.
Well PUBG makes sense as its known to be poorly optimized. As for fortnite, perhaps turning vsync on is a good idea, sure that will damper your FPS but it would mean not wanting to spend $600+ on a monitor. And honestly if screen tearing is still an issue just go buy a gsync compatible freesync monitor, most are way cheaper than their gsync counterparts. Something like the AOC Agon AG241QX would do.
- Ribbons : 270
2019/05/19 08:25:12
Turn Vsync on. Capping framerate doesn't prevent tearing. The only way to prevent tearing is for the image output buffer to be synced with the monitor. Capping the framerate doesn't sync the output buffer with the monitor.
arestavo
- Ribbons : 76
2019/05/19 08:28:25
My understanding is that the 900 series was MUCH better with CS:GO FPS at low settings/resolutions. Probably a change to the architecture that is the difference.
- Ribbons : 135
2019/05/19 09:45:46
MadmanRB
Actually it's more like bouncing around 55 FPS and always being over 60 FPS. That's what the extra 15% or so gets you. The same reason for overclocking both the CPU and GPU. In aggregate, I gain at least another 20-25% in FPS. Secondarily, nobody was saying he 'should switch platforms' that would be silly. If he WERE BUYING NEW, would you suggest AMD or intel for gaming? I don't appreciate being called a fanboy or that drinking affects my ability to offer sane reliable advice. Meh, not impressed with your opinions.
ItsWolfee
2019/05/21 11:01:34
Now maybe someone can answer this I have a 600w power supply and 2700x is overclocked and also my 1080ti is and I haven’t had any stability issues or crashing or anything would that be enough or go for like a 750?
DRY_ICE
2019/05/21 23:17:42
Without knowing your full system specs it's hard to tell if 600W is "enough", but I'd venture to say that it's cutting it close to the max on an overclocked system. A good rated/efficient 700+W with again only knowing your cpu/gpu would be better in my opinion. You can use tools such as https://www.evga.com/power-meter/ to get an idea of what's recommended.
