JGLuxe
- Ribbons : 17
Hey guys, I just bought an LG UE590 28" 4K Monitor (3840 x 2160) and the reason I bought it, Is because I used to have a 55" TV connected to my computer and I got it to work a bit smoother thanks to some help I got here, But now that I got a monitor again, The mouse feels like it doesn't move smoothly. I changed the monitor settings to "Game" and I haven't been able to find anything else I can change in order to make the mouse movement smoother, It bothers me, Because it feels like the mouse is twitching slightly and drives me crazy! Any help would be appreciated!
i9-12900ks @ | 128GB DDR4 | RTX 3090 FTW3 ULTRA
Randolla
Re: New monitor, Need help with mouse settings
2017/04/17 16:00:18
Have you tried playing around with the mouse settings? Do different DPI settings have any effect?
Intel 5930K@ 4.3 Ghz ASUS Rampage 5 Extreme Motherboard EVGA GeForce 1080Ti SCCase Labs Merlin Full Tower case NZXT Kraken X61 Liquid CPU cooler 32 Gbs G.Skill Ripjaws 4 DDR4 2666EVGA Supernova P1200 PSUAcer Predator X34 MonitorSamsung 512 Gb XP941 M2 SSD HT Omega eClaro Soundcard[
JGLuxe
- Ribbons : 17
2017/04/17 16:34:48
Randolla Have you tried playing around with the mouse settings? Do different DPI settings have any effect?
I tried changing it to slow, turning on/off acceleration and I've tried high DPI's and low DPI's, All do the same thing. I'm sort of lost. It's like the mouse moves a couple MS slower than when I move it.
KenMcC
- Ribbons : 21
2017/04/17 16:54:24
What mouse? maybe it is dying. what is your Video card? cpu, amount of memory? mobo?
KenMcC Z170 Classy K; i7-6700 CPU, Corsair CMK16GX4M2A2400C14 Seasonic SSR-360GP 360W; Samsung 950 Pro M.2 256 GB Samsung 850 Evo 500 GB SATA Samsung 850 Evo 256 GB SATA Samsung SSD 840 Series 250 GB SATA Samsung 860 EVO 1 TB SATA Windows 10 x64 Prof.
JGLuxe
- Ribbons : 17
2017/04/17 17:55:47
KenMcC What mouse? maybe it is dying. what is your Video card? cpu, amount of memory? mobo?
It's a brand new Razer Mamba so I doubt it! I have a GTX 970, 4 GB of RAM.
KenMcC
- Ribbons : 21
2017/04/18 11:49:24
Great, I hope your info helps others to have more ideas
Nozler
2017/04/18 13:16:45
2017/04/18 13:45:01
What is your OS ? Device Manager shows ? Using wired or wireless ? Seems to be many 1 egg reviews on Newegg, others with the same issue you are having Did you get the factory drivers ? razerzone.com excerpt Razer Synapse registration (requiring a valid e-mail), software download, license acceptance, and internet connection needed to activate full features of product and for software updates. After activation, full features are available in optional offline mode.
bdary
- Ribbons : 116
2017/04/18 15:09:54
Check your mouse settings through it's software. Make sure the polling rate is set to at least 1000ms.
JGLuxe
- Ribbons : 17
2017/04/23 15:55:30
Nozler You could Try Mark C mouse fix to see if that may help http://www.makeuseof.com/...ndows-10-mouse-issues/
Thanks! I'm not sure if it was the Mark C or the fact that after reading that, I set my size to 125% and somehow fixed it, I guess it looks choppy on 150%. This also stopped my pointer from freezing (That, I believe was because of the Mark C). Thanks!
