Hot!Need help with watercooling.
Nike_7688
Re: Need help with watercooling. 2021/04/13 08:59:15 (permalink)
Sorry, I just saw you were looking for help finding tubing. The EK tubing Rainstrike suggested does show up as 9.5/12.7mm on EK's website.
They have it in stock at Performance-PCs. You can buy 3-meter boxes or cut-lengths.
i9 11900k @5.3GHz-all-core - EVGA Z590 FTW - EVGA GTX 2080 Super XC Hybrid - 32GB 3733MHz CAS16 G.Skill, gear1 - WD SN850 2TB NVMe Gen4 - BeQuiet! Dark Base 900 Pro. Project Dark Water MODS RIGS post for build notes.
12G-P5-3968-KR 6/3/2021 7:44:28 AM PT No
#31
rmorse27
  • Ribbons : 14
Re: Need help with watercooling. 2021/04/13 09:50:39 (permalink)
The one thing I can tell you is let the pump run for 24 hours to test for leaks before firing up pc, cover the components with rags or paper towels incase of leaks, I f everything is ok next day fire up and enjoy. Rule of thumb 1 rad per cpu or gpu depending on your set up.
 Intel i7 10700k 32 GB Corsair Ram 3600MHZ-MSI Z490 Gaming Plus Board EVGA RTX 3070 FTW3 ULTRA - Inland Platinum 2 TB M.2 NVME Drive - EVGA 850 GS PWS-Thermaltake Open Air Case-EK Kinetic Pump/Res -360 Radiator & 240Radiator- LG 32 Inch G-synch 2k Monitor.
 http://www.heatware.com/eval.php?id=66896
#32
Nex_Lupus
  • Ribbons : 31
Re: Need help with watercooling. 2021/04/13 10:22:49 (permalink)
rmorse27
I got a 140mm quad on just the cpu
Also motherboard is 90 degrees so won't have many components near the wb and the few things exposed may be a hdd and cables and a psu.
http://www.heatware.com/eval.php?id=67306
STOP PIRACY - Sorry but pirates stole the link
#33
tattude69
Re: Need help with watercooling. 2021/04/14 07:14:33 (permalink)
i would suggest a good fan controller for the fans and the pump. When i first went water cooling i was using splitters and trying to use the motherboard, results were hit or miss. it was suggested here on the forums to try Aquacomputer OCTO. After almost a year i could not be happier best money i spent $56 for OCTO and $10 for RGB splitty (4 fan hub also allows control of Corsair RGB fans without corsair software,Hubs or lighting node). I am able to run 10 fans 1 DDC pump and 4 temperture sensors. you can used fixed rpms or set fan curves using your choice of Temp inputs (cpu or gpu). This only works with PWM fans and pumps. Welcome to the club. Far as leak testing my wife bought me an MSI MPG Z490 Carbon EK X mobo and it came with an EK Leak tester. ($40) It was so easy to use and by the time i put water in my system i had no concern of a leak took 2 hours vs 24 hour leak test. Will never go back to the 24 hr leak test. This forum is one of the best i have found for everything pc.
Thums up 👆 to the Whole Community
post edited by tattude69 - 2021/04/14 07:16:46
#34
Nex_Lupus
  • Ribbons : 31
Re: Need help with watercooling. 2021/04/14 09:47:21 (permalink)
tattude69
Links please?
#35
tattude69
Re: Need help with watercooling. 2021/04/14 12:49:06 (permalink)
Here's the link for the Aquacomputer it was sold out when I wanted it but they got one within 2 weeks great bunch of guys
https://modmymods.com/aqu...or-pwm-fans-53286.html
Leak tester not the cheapest but free shipping you can find the best deal for you
https://www.amazon.com/dp...ncoding=UTF8&psc=1
#36
nick_shl
Re: Need help with watercooling. 2021/04/14 17:36:25 (permalink)
tattude69Leak tester not the cheapest but free shipping you can find the best deal for you
Tire valve + fitting and air compressor may be a good DIY alternative.
Use associate code to save 3% on your EVGA GPU purchase! And up to 10% on other products! SV9XHVOJXMZFCEX
Note: all associate codes are equal. Don't expect to get 10% off your GPU purchase by using someone else code.
"BUYER DISCOUNT PERCENTAGES" for all products can be found here.
24G-P5-3989-KR Queue tracking
#37
tattude69
Re: Need help with watercooling. 2021/04/14 18:42:34 (permalink)
A Mitty Vacum pump for auto will work also. Just be careful how much psi you use for EK products keep it between. 0.5 bar to 0.75 bar
post edited by tattude69 - 2021/04/14 18:49:35
#38
Armons account
Re: Need help with watercooling. 2021/04/28 10:16:01 (permalink)
I would just stay with the traditional AIO. If you want superior AIO performance, get a 360mm AIO from a trustworthy company (Cooler master, nzxt, corsair, etc) but make sure your case can fit a 360mm radiator.
Rig specs: Rtx 3070 FE, 5900x, 64gb crucial ballistix 3600mhz CL16 RGB Ram,  addlink 2tb nvme ssd, WD SN750 1tb nvme ssd, 240mm coolermaster AIO (for cpu) custom loop (ekwb block, XSPC pump/res, Thermaltake 360mm rad) for GPU, ASUS B550 XE, corsair RM850x, Lian Li Lancool II mesh
#39
ddog661
Re: Need help with watercooling. 2021/04/28 18:20:57 (permalink)
I also want to get into building a loop! Maybe in my next build (:
EVGA Associate Code: S7J93UZF57CEOFM
Elite Program Referral Link: https://www.evga.com/member/elite/?referralid=NHS68RYWQ0PFNE7WHFBB
Use the associate code when purchasing an item or use the link when you meet the requirements to become an elite member (if you so desire)
#40
FloodControl
Re: Need help with watercooling. 2021/04/29 13:31:07 (permalink)
Nex_Lupus
just looked into it myself probably is a metric vs imperial. Which sucks for me, I cannot find any stock ekwb tubing...
they label them as 9.5mm and 12.7mm id/od instead of standard 10/13 (even tho that is what they mainly state it as)
If you want to outsource tubing to something 3rd party, I recommend Tygon B-44-4X tubing. It's compatible with EK fittings, is food grade (less plasticizer leeching into your coolant loop), and is quite flexible. The only issue I've ever had with it is that colored coolant will eventually lightly coat the inside of the tubes, but I'm using big fat 1/2" ID tubing so that may be more an issue with a lower linear flow rate. It doesn't affect the cooling performance at all, it just looks kinda nasty after a while.
#41
nick_shl
Re: Need help with watercooling. 2021/05/07 10:48:56 (permalink)
Armons accountI would just stay with the traditional AIO.
Speaking about AIO and copper/aluminum... EVGA CLC 360mm All-In-One RGB LED CPU Liquid Cooler, 3x FX12 120mm PWM Fans, Intel, AMD, 5 YR Warranty, 400-HY-CL36-V1
Specs:
Waterblock Material: 100% Copper
Radiator Material: Aluminum
Warranty: 5-Year Limited Warranty
Junk?
#42
inevereven
Re: Need help with watercooling. 2021/05/07 15:29:23 (permalink)
nick_shl
Specs:
Junk?
The material choices are not ideal but for an AIO it's not as big of a deal as non of the parts will be exposed to air which can cause faster oxidation/corrosion. Also way easier to replace if it doesn't perform as well after a few years.
#43
nick_shl
Re: Need help with watercooling. 2021/05/09 19:59:10 (permalink)
ineverevenThe material choices are not ideal but for an AIO it's not as big of a deal as non of the parts will be exposed to air which can cause faster oxidation/corrosion. Also way easier to replace if it doesn't perform as well after a few years.
It was rhetorical question for guys who claimed on previous page of this topic that "you should never ever use mix copper and aluminum".
#44
FloodControl
Re: Need help with watercooling. 2021/05/10 05:18:12 (permalink)
nick_shl
Specs:
Junk?
It's possible they're still using copper/brass tubes in conjunction with aluminum fins. Since rads are painted, there's no opportunity for oxidation of the aluminum. The fluid would only see copper/brass in that situation, so no corrosion from that end either.
#45
