OGCrescent
Good morning guys, I have a question about my Ram and Mobo. I have recognized yesterday, that my DDR4 Ram is not running on the highest Mhz as it normally should. I tried to activate the XMP setting with 3000 mhz but my couldnt reboot after saving the settings. Does someone have any advice for me :/ ? regards oliver
GGTV-Jon
- Ribbons : 19
Re: Need help with my z370 FTW and DDR4 Hyper x Fury Predator 3000mhz!
2018/11/06 00:05:13
Part number for your memory so peeps can see exactly what you have What bios version, cpu ect as well
OGCrescent
2018/11/06 03:18:56
I do have an i5-8400, bios 1.09 should be the newest!
Hyper X Predator 3000Mhz 2x8GB HX430C15PB3K2/16
2018/11/06 09:53:16
Try setting the ram manually.
OGCrescent
2018/11/06 09:58:49
Ok, 3000 or less? And do I have to care about the latency? As example 15/35/35/60 idk what it means, but do I have to take care off?
2018/11/06 10:13:25
3000, 15-17-17-2T, 1.35v That is what you want to set.
OGCrescent
2018/11/06 10:22:00
Thank you will try it later or tommorow, I will let you know if it worked!
2018/11/06 10:22:59
OGCrescent
2018/11/07 00:37:00
Well... there many settings, like TCL, tRCD/tRP, tRas, tRRD _ S, tRRD_L, tRTP, tFAW,tCWL and tCMD
GGTV-Jon
- Ribbons : 19
2018/11/07 00:46:56
Go into the bios, memory tab then hit F12 for a bios screen shot - you must have a USB thumb drive plugged in for it to be saved Post the screen shot of your memory settings and we can help you
OGCrescent
2018/11/07 01:13:02
OGCrescent
2018/11/07 07:50:26
Can you See the picture guys? :o
GGTV-Jon
- Ribbons : 19
2018/11/07 08:48:24
We can see one. If you have a thumb drive plugged in and hit F12 on the screen it will export a screen shot, they will be much clearer then a picture with your phone of the screen You can only have 500kb worth of attachments per post so you might have to make a few posts but primarily the first / top half of the memory page. I was going to let Sajin look at your shots and make the recommendations as to your settings
OGCrescent
2018/11/07 08:57:21
I tried already, but he did not recognize my USB. Thats why I ve uploaded it this way, I thought the Resolution and the sharpness should be fine, but If you cant See it or have problems with it, I try it again. Thank you for your help so far!
GGTV-Jon
- Ribbons : 19
2018/11/07 09:02:11
OGCrescent I tried already, but he did not recognize my USB. Thats why I ve uploaded it this way, I thought the Resolution and the sharpness should be fine, but If you cant See it or have problems with it, I try it again. Thank you for your help so far!
Was it plugged into a hub? If so try plugging it directly into the back
GGTV-Jon
- Ribbons : 19
2018/11/07 09:08:26
I just looked at my folder with saved bios screen shots. Default saved images are BMP at 2.3mb(ish). I use GIMP and export as JPG image, drops the file size to 250kb, you can then get 2 images in per post. If you re-scale from the default 1024x768 you might get the number lower but I don't think it is enough for more.
OGCrescent
2018/11/07 09:12:31
Oh yea.. my fault, I will do it later!
2018/11/07 09:49:21
Set memory profiles to manual. Set memory frequency to 3000. Set DIMM Voltage to 1.35. Set tCL to 15. Set tRCD to 17. Set tRP to 17. Set tRAS to 35. Set Command Rate (CR) to 2T. Save and exit the bios. Note: You may need to set your vsa & vccio voltages to 1.35v as well.
post edited by Sajin - 2018/11/07 09:52:02
OGCrescent
2018/11/07 14:29:47
I tried, sadly no succes :(
00,4C,FF error code
OGCrescent
2018/11/07 14:43:59
Now, I tried same with XMP 2 (2666)mhz, this one worked.. why I dont know, maybe pre-set with 2933mhz could work?
2018/11/07 14:52:20
Did you try to up your voltages? Wouldn't hurt to try 2933.
OGCrescent
2018/11/07 15:00:36
Ye, I swear I did all you suggest!
2018/11/07 16:31:26
Hmm. Maybe the cpu needs a small oc to be applied before the ram can run at 3000 MHz.
OGCrescent
2018/11/10 01:30:22
How should it look like?
I mean the "small oc"
2018/11/10 12:42:39
Your cpu isn't overclockable.
OGCrescent
2018/11/11 03:27:14
I know, but you told me 1 Post earlier :D
