- Ribbons : 115
Re: Need help with my Hard Drive (Partitions)
2019/01/02 21:22:35
Downloaded Minitool but there's no option to extend like it say's on that website.
2019/01/02 21:28:09
- Ribbons : 115
2019/01/02 21:50:00
I tried another program, and the extend option is not there either. Cannot extend a "Dynamic Disk".
2019/01/02 22:03:52
XrayMan I tried another program, and the extend option is not there either. Cannot extend a "Dynamic Disk".
PM'd.
Hoggle
2019/01/02 22:36:25
If it's saying Dynamic Disk it would seem like that would be for like a RAID setup or possibly from the drive having a protected backup file like a Laptop backup section of the hard drive. If I had to guess since you are saying it's not that large it's probably from loading a RAID driver when Windows was installed.
- Ribbons : 115
2019/01/02 22:42:11
No program will allow me to convert the dynamic disk to basic unless I pay for the programs. Won't extend unless the disks are converted to basic. :(
- Ribbons : 115
2019/01/02 22:56:01
Thanks to everyone trying to help. Extending the partitions isn't going to happen. Thanks for trying.
2019/01/02 22:58:12
2019/01/02 23:14:24
☄ Helpfulby XrayMan 2019/01/03 01:27:40
Found a free solution for you. Check PM.
- Ribbons : 115
2019/01/02 23:39:08
Ok that program changed it to basic, however it still won't extend more than 455MB's. I don't get it! Sigh!
- Ribbons : 115
2019/01/02 23:50:33
I think it's trying to take that unallocated space next to C in the G drive. I need to somehow move the other unallocated space to go after the C drive so it picks up that instead. Not sure how to do it though.
- Ribbons : 115
2019/01/03 01:25:03
2019/01/03 06:38:26
No problem.
Doomed83
2019/01/03 11:51:22
Glad to see you got this worked out. Wish I'd have seen it sooner, but just as an FYI to anyone else the windows extend partition function will only extend to empty space immediately "to the right" of the partition you wish to extend. So if you have for example a "C:" partition followed by a "E:" partition followed by "unallocated" space you cannot extend the "C:" partition to the "unallocated" space because the "E:" partition is between the "C:" partition and the "unallocated" space. (picture below for example) I hope the explanation makes sense and possibly helps someone in the future.
- Ribbons : 115
2019/01/03 19:56:03
Delirious Just my opinion, but when you get all the drives where you want them, defragment them.
I did earlier. Drive C took a long time, but it helped. Saved 3Gb of space, and it's noticeably faster.
- Ribbons : 115
2019/01/03 19:59:23
Doomed83 Glad to see you got this worked out. Wish I'd have seen it sooner, but just as an FYI to anyone else the windows extend partition function will only extend to empty space immediately "to the right" of the partition you wish to extend. So if you have for example a "C:" partition followed by a "E:" partition followed by "unallocated" space you cannot extend the "C:" partition to the "unallocated" space because the "E:" partition is between the "C:" partition and the "unallocated" space. (picture below for example)
Yep. Had to use a 3rd party program, because the wrong drive was on the right side. Then used the other program to extend the drives.
notfordman
- Ribbons : 28
2019/01/04 11:24:48
Glad you got it fixed. Thanks Sajin and others.
