Need help identifying couple components of a 2977-KR GTX 970 SC
Karalux
2020/10/03 08:22:38 (permalink)
Hello, the situation is that i bought a broken EVGA GTX 970 SC (2977 version) with fixing and using it as a daily driver in mind since im tight on budget. The problem i found in it was a classic gpu core power supply mosfet burn-out which was "fixed" by soldering an inappropriate mosfet in its place, hence the card was dead. So i desoldered the mosfet and the card came back to life. I ordered couple of replacement mosfets and couple controllers or it (to change them too, just in case) but the problem is that at the moment i didnt have a normal hot air soldering station so i used adjustable temperature hot air fan which did not have adjustable speed, hence while soldering it blew away couple of resistors and capacitors which i could not find. I need help identifying those lost components since its the last thing i need to fully fix this card. The components i need to find values of are circled in red (and if possible of those 4 in small green circles nearby, since i cant remember if i havent touched them too). Thank you in advance
imgur.com/XF9nsy2
Edit: added link to the photo
post edited by Karalux - 2020/10/03 11:54:07
2 Replies Related Threads
    themlharris
    Re: Need help identifying couple components of a 2977-KR GTX 970 SC 2020/10/04 07:07:58 (permalink)
    Hmm interesting. I’ll do some digging and see what I can find.
    Karalux
    Re: Need help identifying couple components of a 2977-KR GTX 970 SC 2020/10/07 00:25:00 (permalink)
    That is what i came up with a help of somebody from another forum, hope its true
