vipers33
Colleagues, help me.How to buy power supply for EVGA 1080ti sc I have a cheftec 750W now, but he is already 8 years old, his 12V line has only 18A which gives 216W on this line and when I play off my computer. What to buy 650W or 750W and what. My types: 1 - EVGA SuperNOVA 650 G2 650W 2 - SeaSonic PRIME 650W 3 - Corsair RM650X 650W If 650W is not enough, then I am considering the same models but 750W. Help
post edited by vipers33 - 2017/06/06 08:21:20
Re: Need advice in choosing because I have a problem
2017/06/06 11:13:02
650w is plenty. I'd get the 750w though just for extra head room. I'd go with the Seasonic 750w Prime.
vipers33
2017/06/06 11:33:49
Sajin 650w is plenty. I'd get the 750w though just for extra head room. I'd go with the Seasonic 750w Prime.
I understand that you are suggesting that for a quiet head to buy 750W And what about the EVGA SuperNOVA 750 P2, 80+ PLATINUM? Are you on the same horizontal, is it weaker or better?
2017/06/06 11:42:37
panzlock
2017/06/06 18:28:50
vipers33 I understand that you are suggesting that for a quiet head to buy 750W And what about the EVGA SuperNOVA 750 P2, 80+ PLATINUM? Are you on the same horizontal, is it weaker or better?
I'd go with the P2. P2's are well made Super Flower builds. The G2 and GS series have been plagued by problems based on consumer reviews. And saw some issues on this forum, as well. Stay away from the GS series, in particular.
vipers33
2017/06/07 07:37:34
Thanks gentlemen for help I now have two power supplies in my head: Super Flower Leadex Platinum 750W and SeaSonic PRIME Platinum 750W And ... I'm tempted to be at Seasonic because in reviews it gets 1-10 points in 10 points
MSim
- Ribbons : 38
2017/06/07 12:19:42
If you have they money, go with SuperNOVA 750W P2 or the Seasonic Prime 750w.
vipers33
Re: Power Supply Needed for GTX 1080 Ti SC?
2017/06/07 13:26:25
Sajin, I have the same, from here my replacement of the power Chieftec 750-14c (10 years ) supply because on the + 12V line I have only 18A and this gives 216W, it is very little to 1080Ti.The computer in the 3D games and in the tests is restarting.Green card not twisted at rest 30 *C in the players does not exceed 50 *C I hope it's a power adapter and not a card. For your advice, Saijn bought Seasonic Prime 750W and see if it helps because it has + 12V lines -> 62A. Of course, I also ran pure graphics drivers and did not help.
post edited by vipers33 - 2017/06/07 13:39:33
vipers33
2017/06/07 13:56:11
vipers33 Sajin, I have the same, from here my replacement of the power Chieftec 750-14c (10 years ) supply because on the + 12V line I have only 18A and this gives 216W, it is very little to 1080Ti.The computer in the 3D games and in the tests is restarting.Green card not twisted at rest 30 *C in the players does not exceed 50 *C I hope it's a power adapter and not a card. For your advice, Saijn bought Seasonic Prime 750W and see if it helps because it has + 12V lines -> 62A. Of course, I also ran pure graphics drivers and did not help.
The new psu should fix you up.
P.S Saijn Ah, I forgot to add that as I change the resolution to 1440p or 2160p I also restart. Does the power supply also have an impact on this?
vipers33
2017/06/07 14:24:59
2017/06/07 14:44:07
vipers33
2017/06/07 15:03:37
2017/06/07 17:07:56
No problem.
