NVIDIA Finally Fixes Multi-Monitor Power Consumption of Turing GeForce 20.
GTXJackBauer
  • Ribbons : 48
2018/11/08 21:24:48 (permalink)
NVIDIA Finally Fixes Multi-Monitor Power Consumption of Turing GeForce 20. Tested on RTX 2070, 2080 and 2080 Ti.
Today, NVIDIA released their GeForce 416.81 drivers, which among others, contains the following changelog entry: "[Turing GPU]: Multi-monitor idle power draw is very high. [2400161]". Back at launch in September, Turing was plagued with very high non-gaming power consumption, in both single-monitor and multi-monitor idle.
The company was quick to fix single-monitor power consumption, which we tested promptly. Unfortunately, at the time, multi-monitor power draw wasn't improved and people were starting to get worried that there might be some kind of unfixable issue present on Turing that would prevent NVIDIA from fixing multi-monitor power draw.
Using today's 416.81 drivers I did a few quick runs for power consumption on all three existing GeForce 20 SKUs; the RTX 2070, RTX 2080 and RTX 2080 Ti.
As you can see, multi-monitor power consumption is finally back at normal levels. Good job, NVIDIA! While the power draw of Pascal cards is still a little bit lower, the differences are now negligible, and won't have any significant effect on power usage, power bill, temperatures, or the environment.
I also did a run measuring single-monitor idle power - no changes here, but not needed either. In case you wonder, since these changes are part of the driver, nothing special will have to be done for custom boards from the various NVIDIA partners. No BIOS update needed, just install the 416.81 drivers and multi-monitor power consumption will go down by more than half.
Source
LMD3DNZM9LGK8GJ
2 Replies Related Threads
    HaywireHaywood
    Re: NVIDIA Finally Fixes Multi-Monitor Power Consumption of Turing GeForce 20. 2018/11/09 01:59:32 (permalink)
    Great improvement, but the difference between pascal and turing isn't negligible.  1080ti in dual monitor is 11w and the improved 2080ti is 21w, so just shy of double the power consumption if that is a driving concern.
    Heatware Affiliate code: QLF0RY1CK9
    RB2021
    Re: NVIDIA Finally Fixes Multi-Monitor Power Consumption of Turing GeForce 20. 2019/04/23 12:36:29 (permalink)
    With 3 monitors my idle consumption sits well over 40W with my 2080. This goes way down if I go back to 2 monitors or 1. With 2 monitors I get the gsync flicker. I wish this would be addressed because it makes my fans click on and off as the card isn't cool enough in fan stop mode.
