Wouldcrash
Hello everyone, for a while now i try to get my nu audio on my threadripper workstation up & running, but it doesn´t want to. I tried different adapters from 16x to mini pcie, down to server & mining adapters. Still it doesn´t want to work. My motherboard only has 16x pcie gen3 slots, can some1 pls help me further. I don´t have the money to buy a new board atm. Best Regards, Wouldcrash
transdogmifier
- Ribbons : 17
Re: NU Audio doesn´t work with my GIGABYTE X399 AORUS PRO Workstation-Motherboard
2021/05/21 04:41:09
Would, can you post your specs out like in my sig? If you haven't tried the full size slot for the card, please do...it should work there too...
Wouldcrash
2021/05/21 04:50:26
- CPU: AMD Ryzen Threadripper 2970WX WOF
- CPU Kühler: Cooler Master MasterLiquid ML360 RGB TR4
- Motherboard: GIGABYTE X399 AORUS PRO
- RAM: thermaltake TOUGHRAM RGB 64 GB DDR4-3000 Quad-Kit
- PSU: Rhombutech® RT-1250p
- GPU: EVGA NVIDIA GTX 970 in 2weeks is it a A4000
Wouldcrash
2021/05/21 04:53:06
PSU has dedicated cable to the NU-Audio & Avermedia 4k capture-cards are in the system.
bob16314
- Ribbons : 761
2021/05/21 05:12:32
transdogmifier
- Ribbons : 17
2021/05/21 05:18:15
bob16314 See How to troubleshoot if I am experiencing issues with my EVGA NU Audio Card? in the EVGA FAQs if you haven't yet..You can also search 'NU Audio' in the FAQs and get other hits.
You might also update your mobo BIOS to the latest version if you haven't yet and is needed. That's all I have..Good luck.
The latest is from December 2019, F2 (if he has Rev 1.0 of the board)....only 2 BIOS available. I might try (if you have F2) resetting the bios and try again...but the link Bob gave is about all I would have too.
Wouldcrash
2021/05/21 05:39:09
i have the F2 version. isn´t there a way so that i maybe just change bois settings or so?
transdogmifier
- Ribbons : 17
2021/05/21 05:42:33
Wouldcrash i have the F2 version. isn´t there a way so that i maybe just change bois settings or so?
Sure if you go into bios, but I don't know the BIOS at all....
Wouldcrash
2021/05/21 08:05:33
i changed some values in the bios, but the Nu Audio doesn´t want to work. I contacted the manufacture Gigabyte in the hope that they maybe have a idea, let´s see. Has somebody else any experience or idea with this issue?
bob16314
- Ribbons : 761
2021/05/21 08:53:23
In the Peripherals section of the BIOS you can try disabling the normally enabled HD Audio Controller which is for the on-board/motherboard audio and maybe then it will switch to using the NU Audio card instead, dunno.
transdogmifier
- Ribbons : 17
2021/05/22 04:40:58
The only other thing I can think of to try is to see if it works in another system....do you have another PC (a friends or your own) to plug it into?
MhzManiac
- Ribbons : 8
2021/05/24 06:57:34
Make sure the power connector is a direct from the power supply and not a molex adapter; as it needs 3.3 volts to operate. I made that mistake myself. Does it light up? If so, then your power connector is fine.
That is me in the picture, anyone else ever pet a live Lion?EVGA Z390 FTW (Bios 1.08) i9-9900KF 8 core, 32G Corsair Vengeance LPX Dual Chl 3000 XMP-1 , Intel SSD6 M.2 2TB, Samsung 840 PRO 1TB / 512G SSD, Gigabyte RTX 2080 Super , Win 11 Pro 64, EVGA Supernova 1300 watts, NZXT Phantom 820, Strix Raid DLX 7.1 surround, Corsair H100 Liquid , Dell S2417DG /S2409W / Acer XB241H Predator / Samsung C24F390 Curve/ Oculus Rift S VR
man114
2021/05/26 04:21:58
I have one in my gigabyte gaming 7 x399 which is essentially the same board with lots of RGB.
There shouldn’t be any issues whatsoever.
Top down I have the pcie slots as 2080ti, Fusion IO 3.2tb ssd, nu audio, Fusion IO, Fusion IO. I have the same CPU as you and ran the nu audio under a very early BiOS and the most recent.
Wouldcrash
2021/05/26 04:35:00
ok, thx for the information. i gonna buy a new power-connector & check if there is maybe an issue with that. THX Guys
transdogmifier
- Ribbons : 17
2021/05/26 04:42:31
Wouldcrash ok, thx for the information. i gonna buy a new power-connector & check if there is maybe an issue with that. THX Guys
Have you disabled the onboard sound? Try that too
Wick3ed
Flagged as Spam (1)
2021/06/02 18:09:55
