Re: NU Audio Pro - Coil whine coming through?
2020/03/20 12:40:35
Yes, I tried that as well. Figured that would be a good place to start, i have modular power supply and it has 2 completely separate 12v rails, I tried splitting them and had no effect. Like i said before the best thing I did was move them the farthest away possible. Problem is now, I am using 3 monitors, my 2 side monitors are older monitors and only have DVI inputs, so i am running a second video card gtx670 for the outputs and that card is much closer to the NU audio card so I get a lot of static when moving things or using my 2 side monitors.
