turbopenguin
So how precise is the software, because the software shows such a high number that even with my setup sounds a bit far fetched.. Any thoughts anyone?
Main Rig - Phanteks Evolve Shift AMD Ryzen 7 2700X Gigabyte AB-350N Corsair DDR4 16GB 3600MHz EVGA GTX 1080 Corsair SFX 650W Western Digital SN720 m.2 1TB SSD
Vlada011
- Ribbons : 11
Re:NEX 1500 Supernova Power Reporting Accuracy
2013/03/16 04:36:12
My software show numbers pretty accurate... Input power is I think how my system really need. 12V rail when I change from 12.15 to 12.10V example AIDA64 notice exatly 0.05V change, onle numbers are little difference... But like you know sensors is always good to have voltmeter but you will see voltmeter react exactly on change/tune voltage with software on 12V rail...
turbopenguin
2013/03/17 00:09:14
Well I'm just skeptical of the 1672 Watts and 15.42 Amps.
_Nite_
- Ribbons : 46
2013/03/18 16:54:44
It's not accurate, someone here on Geforce Titan subforum had 4 x GTX Titans in SLI running off a EVGA 1500w and it burned up on him and he was pulling like 1600w from the wall.
post edited by _Nite_ - 2013/03/18 16:59:29
Gaming Rig: AMD Ryzen 7 2700x @ 4.25Ghz - Asrock B450 Pro 4 - 16GB Crucial Ballistix DDR4 3000 - 240GB SSD (OS), 1TB ADATA SU800 SSD and 2TB ADATA SX8200 Pro M2 NVME (Games) - 8GB RTX 3070 XC3 Ultra - Sound Blaster Audigy 5 RX - EVGA Supernova 750w G2 - Antec 302 - 24" Asus VG248QE
wizzard1709
2013/03/18 18:15:02
_Nite_ It's not accurate, someone here on Geforce Titan subforum had 4 x GTX Titans in SLI running off a EVGA 1500w and it burned up on him and he was pulling like 1600w from the wall. But somehow this makes now sense to me, Guru 3d tested with 3 way -SLI and per Titan they reached approx 250 Watt. In all the other tests I read, the power consumption was the same. When we assume 1000 Watt on graphic cards, there is 500 Watt left for system. And with his OC you will never reach 500 Watt. Because of this I can't believe that he burned up his PSU.
Banchetto 101, Tt 1500,Xeon W 3540, 3 x 2 GB Dominator GT 2000MHz CL8, P6T6 REVOLUTION, 570 GTX Sonic, Xonar STX Essence, SSDs: A-Data 128GB XPG SX 900+Corsair X128 GB, Veloci Raptor 300GB, WD Black 1TB/ S.T.R.I.K.E. 7,RAT 7 EVGA X58 SLI Classified 759, Silverstone 1200W, i7 965X, 3 x 2GB Dominator 1600, 2 x Evga 295 GTX with Aquagraf, SSD Verbatim 128GB, Lian LI P80, diNovo Edge, Mamba Other fun stuff: Hailea water chiller. Koolance CPU-LN My Affiliate Code 6LQ5H2AR45
_Nite_
- Ribbons : 46
2013/03/18 18:29:05
wizzard1709 _Nite_ It's not accurate, someone here on Geforce Titan subforum had 4 x GTX Titans in SLI running off a EVGA 1500w and it burned up on him and he was pulling like 1600w from the wall. But somehow this makes now sense to me, Guru 3d tested with 3 way -SLI and per Titan they reached approx 250 Watt. In all the other tests I read, the power consumption was the same. When we assume 1000 Watt on graphic cards, there is 500 Watt left for system. And with his OC you will never reach 500 Watt. Because of this I can't believe that he burned up his PSU. well he posted here that it started sparking (the rice krispies type joke) when he was running 3dmark 11 http://forums.evga.com/fb.ashx?m=1883469 then he posted here he is pushing the limits of the PSU with the replacement as well http://forums.evga.com/fb.ashx?m=1887556 after that he posted he had to install a 240v breaker cause he wen't over 1600w http://forums.evga.com/fb.ashx?m=1889706
post edited by _Nite_ - 2013/03/18 18:34:31
wizzard1709
2013/03/18 19:06:11
_Nite_ wizzard1709 _Nite_ It's not accurate, someone here on Geforce Titan subforum had 4 x GTX Titans in SLI running off a EVGA 1500w and it burned up on him and he was pulling like 1600w from the wall. But somehow this makes now sense to me, Guru 3d tested with 3 way -SLI and per Titan they reached approx 250 Watt. In all the other tests I read, the power consumption was the same. When we assume 1000 Watt on graphic cards, there is 500 Watt left for system. And with his OC you will never reach 500 Watt. Because of this I can't believe that he burned up his PSU. well he posted here that it started sparking (the rice krispies type joke) when he was running 3dmark 11 http://forums.evga.com/fb.ashx?m=1883469 then he posted here he is pushing the limits of the PSU with the replacement as well http://forums.evga.com/fb.ashx?m=1887556 after that he posted he had to install a 240v breaker cause he wen't over 1600w http://forums.evga.com/fb.ashx?m=1889706 But maybe the PSU has been faulty. I just don't see the possibility how and with what he wants to reach 1600 Watt. The Titans are not OC monsters, you have no real possibility to change voltage on them at least with software. Therfore I believe there must be another reason why the PSU burned up.
DETH666
2013/03/18 22:31:54
DETH666
2013/03/19 01:08:45
By the way I love the supernova! The twelve volt regulation on some of the very first units were not that great and at my crazy power draw caused stability issues... I very happy with my new unit!
wizzard1709
2013/03/19 09:15:02
DETH666 By the way I love the supernova! The twelve volt regulation on some of the very first units were not that great and at my crazy power draw caused stability issues... I very happy with my new unit! There is an easy way to find out how much Watt you use. You can buy a watt/energy meter and just plug it in. You can get such meters around 30$, in my opinion a small investment compared to the costs of your hardware.
post edited by wizzard1709 - 2013/03/19 09:21:38
DETH666
2013/03/19 09:56:55
that wont cut it do you know where i can get a 230vac 20 amp unit?
wizzard1709
2013/03/19 13:26:46
DETH666
2013/04/15 23:01:41
Vlada011
- Ribbons : 11
2013/04/16 19:43:13
Show your PC, if I can't buy I want to look. What's inside 4x Titans and Intel Black Overclocked. Clear 5000MHz - 5 GHz.
klepp0906
2013/11/28 05:41:17
to add insult to injury, I can corroborate your results. My 4 titans are causing my supernova to shut down randomly during ffxiv and it wont even start furmark. It runs ok if they aren't overclocked but the minute I put juice behind them it kills over. EVGA is sending me a new one after I cited my numbers to them, but im not confident it wil help as those were the numbers I was able to attain non shutdown. God knows what it was pulling when it shut off. supernova software in single rail shows me as drawing 1850 from the wall, 1620 or so out of the psu, and 133A. Id imagine it doesn't take much more to kill it and who wants to run their psu that hard. I never ever would have imagined this rig taking more than 1500w or 2x psu but /sigh atleast ill have enough power for probably every pc I ever build for the rest of my days >.< I want to run OC mode as I may "just" make it with that, but I have no idea how to hook up a 220v outlet and I cant afford to hire an electrician to do so. Not to mention they would likely think im nuts. Im probably going to be stuck pitching a Christmas request (that I would much rather have used for a mouse/keyboard) in the hopes of keeping the rma'd unit they are sending. I'll have to run it outside of my case until I can afford a new one but meh. I find it hilarious that the haters cite the inaccuracy of the software, then move on to the quality of the psu, then tell me that a 1200w corsair would run it fine. lol if that were the case I would gladly grovel and admit ive been wrong.... however evga should be ashamed if its charging the price it is for this unit, and barely able to do 100w over spec when a cheaper unit Is allegedly capable of 600+ over spec :P anyhow, my oc on my chip is weak all things considered (I dropped my good chip on the ground sigh) and I only have 6 case fans and 1 waterpump and 1 optical drive .... 1.212 kills this psu.. I was able to run it at 1.162 problem free but god forbid I wanted to unlock it and run 1.3v ... this psu is simply not quad sli capable in an overclocked system from what I can tell.
i7 8700K - Asus Maximus X Formula32GB Corsair 3600 1TB Samsung 970 EVO Plus SSD12x10TB Seagate Barracuda Pro HDD - EVGA RTX 2080ti HydroCopperEVGA NEX1500 SuperNovaCorsair Obsidian 900D-EK Supremacy-XSPC RX360-XSPC RX240 Arctic BioniX P120 x8 - Swiftech MCP655BWindows 10 Pro x64 - Dell U2718Q x3Razer Tiamat 7.1 v2 - Razer Naga Trinity - Razer BlackWidow Chroma v2
klepp0906
2013/12/01 14:29:39
has anyone directly compared killawatt numbers to supernova numbers to see how close or otherwise they are? Just so we all have a relative idea? I know its pretty darned important to me at the moment. I wish I had one currently. My psu is either faulty, or my rig is drawing an obscene amount of power. Either way i'd love to know which.
cerisettex
2013/12/02 08:52:18
Hi ! This is my PC running at 100% :) CPU : Intel Core i7 3930k 4,9Ghz Mother Board : ASUS Rampage IV Extreme X79 RAM : Corsair Vengeance 16Gb 1867Mhz Video Card : 3-way CrossfireX (Tri-Fire) MSI R7970 Lightning PSU : EVGA 1500W SUPERNOVA Watercooling : Corsair H100 Antec DF-85 I guess measuring it's good with Supernova software :). I have 240-245VAC Outlet lol xD
post edited by cerisettex - 2013/12/02 08:56:17
http://www.modsrigs.com/detail.aspx?BuildID=33501Rig: CPU : Intel Core i7 3930k 5Ghz offset+ LLC High 150%cpu Mother Board : ASUS Rampage IV Extreme X79 RAM : GSkill TridentX 16Gb 2400Mhz (2666Mhz OC!)Video Card : 4-way CrossfireX (QUAD-Fire) MSI R7970 Lightning Boost EditionPSU : LEPA P1700M Maxplatinium 80+PlatiniumSSD : OCZ Agility 4 256GbHDD : X1 1,5Tb + X3 750Gb + X1 3TbWatercooling : SWIFTECH H2O-220 EDGE HD LUQUID : PHOBYA SEXY RED UVCase :Antec DF-85 modded!Total FANs : 16 fans !OS :Windows 8.1 Pro 64bits
cerisettex
2013/12/02 08:59:20
to add insult to injury, I can corroborate your results. My 4 titans are causing my supernova to shut down randomly during ffxiv and it wont even start furmark. It runs ok if they aren't overclocked but the minute I put juice behind them it kills over. EVGA is sending me a new one after I cited my numbers to them, but im not confident it wil help as those were the numbers I was able to attain non shutdown. God knows what it was pulling when it shut off. supernova software in single rail shows me as drawing 1850 from the wall, 1620 or so out of the psu, and 133A. Id imagine it doesn't take much more to kill it and who wants to run their psu that hard. I never ever would have imagined this rig taking more than 1500w or 2x psu but /sigh atleast ill have enough power for probably every pc I ever build for the rest of my days >.< I want to run OC mode as I may "just" make it with that, but I have no idea how to hook up a 220v outlet and I cant afford to hire an electrician to do so. Not to mention they would likely think im nuts. Im probably going to be stuck pitching a Christmas request (that I would much rather have used for a mouse/keyboard) in the hopes of keeping the rma'd unit they are sending. I'll have to run it outside of my case until I can afford a new one but meh. I find it hilarious that the haters cite the inaccuracy of the software, then move on to the quality of the psu, then tell me that a 1200w corsair would run it fine. lol if that were the case I would gladly grovel and admit ive been wrong.... however evga should be ashamed if its charging the price it is for this unit, and barely able to do 100w over spec when a cheaper unit Is allegedly capable of 600+ over spec :P anyhow, my oc on my chip is weak all things considered (I dropped my good chip on the ground sigh) and I only have 6 case fans and 1 waterpump and 1 optical drive .... 1.212 kills this psu.. I was able to run it at 1.162 problem free but god forbid I wanted to unlock it and run 1.3v ... this psu is simply not quad sli capable in an overclocked system from what I can tell. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1500W isn"t enough for your system, you need 2000W but for the moment you cannot find this beast. Use 1500W and buy 1000W PSU. You can dedicate 1000W only for your CPU, and 1500W to your X4 TITANS. If you want to have +230V Outlet you need to buy "amplifier" or something like that to transform tour 220V ..or contact your eletrical service to buy a special subscription for 230V outlet. People who say "How could it possible 1600+W with 4 titans...My answer : EASY. X4 Titans are very very hungry cards. My X3 7970lightning + i7 3930K take 1800W outlet, +1450W output, so imagine with X4 TITANS, its a HELL XD I bought 1500W SUPERNOVA and sadly it was a faulty PSU :((, I send it and recieved RMA - totally "new" (some visible very little screw marks -_-" on PSU) but for the moment it works. My previous Powersupply shutdown itself when playing and idle + error Kernel Power 41. I'm sad that I bough this psu...I should went to LEPA 1600 or something better...1500W Supernova - a curse for me >_<
post edited by cerisettex - 2013/12/02 09:21:06
klepp0906
2013/12/02 10:02:12
let me make sure im understanding you correctly. You had a 1500w and it was causing your pc to shut down (like mine) and you RMA'd it, and the new one fixed the problem? It no longer powers down? This was under load correct? I'm asking in hopes that my new psu will fix the problem for me, since running 2 iis going to be a major pain, financially and otherwise. the psu is supposed to be the "go to" choice for quad sli, yet my cards which aren't even the most power hungry cards out there, literally cripple it. Of course it could be my specific psu and if this RMA'd one no longer collapses under the load, ill be sure to make note. here is a random pic during my time trying to sort out/fix the issue. the 12v output is obviously a misread, it happens when you first open it up if you don't reset it. Normally I just run 2 boxes (input/output power) but I wanted to check amperage and needed to put "something" in the 4th box :P this is on a regular 120v line, I have seen a bit higher on the input (1850ish) but anything beyond is what is causing the shutdowns I "think" if I had a 220v I could run oc mode and perhaps not shut down, but who's to say. The evga CSR said he cant tell me what the failsafe numbers are to trip the protection as they aren't public I guess... so Im shooting in the dark on whether its my pc or the psu causing the restarts.
cerisettex
2013/12/02 10:10:00
Please excuse me for my English, I'm french :) Woow, be very careful, Your system pull 1696W so even OC MODE 1650W isn't enough for you... Try to reduce as you can yours TITANS's Overclock. Put just a official voltage + frequency and launch your system at 100% to see your power consumption. Remember Watt input is measured at wall, then you have power loss => heat so you should take care of output wattage. Normal Mode is 1500W, BUT try to not surpass 1400W. Contact your electrical service, to inquire how install 230V outlet OR install an "amplifier" convert 120V => 230-240. In France (where I live) our outlets are 220-230V BUT our electrical group send to us a little bit more Volts, so that's why I have 235-245V at outlet :). Another Solution is : buying 1000W Power Supply to CPU, and keep 1500W NEX for your TITANS Your Supernova Software is upgraded? My Unit seems to working fine ...but I'm very dissapointed. it's not a new unit but I guess "used" one because of little visible screws marks on gate, back of unit. Wow someone was stupid to put screws at gate and not in special holes. AND little physical damage on the fan in middle (on the fan's stiker just below EVGA logo). Anyway, it's a minor and it's hard to see this "damage" it's ok for me, but it make me a little sad. Anyway it's very hard to see that... The new unit that I recieved works great for the moment, no random shutdown at heavy load, but I need to test 2weeks or 1 month to judge this. I still hear little hissing noise when my PC is OFF, my previous 1500W NEX makes a very loud hissing noise when PC was OFF, the new one is better, BUT there is little hissing noise but I think it's NORMAL. My +3,3V isn't not correct, in previous threads I saw this is because of small cables or something like that, I need to claim a new cables/screws and maybe another unit because of minor physical damage on the "NEW" UNIT from RMA. Don't know what doing now, refund and take my money back and go to LEPA1600... or change psu, totally mad and sad
post edited by cerisettex - 2013/12/02 12:24:43
cerisettex
klepp0906
2013/12/02 13:14:49
Yea I am aware I am at the upper limit. Some people say this software isn't accurate so it isnt using anything near that much. I wish I knew one way or the other.
Still waiting on my rma to ship. Placed it a few days before the holiday and it still hasn't been sent. Even if it does fix the shut downs, I will likely need another one (assuming that software reading is accurate)
Although, after hearing you say your unit shut off and replacing it fixed it, and the private message I just received from another forum member with a rig similar to mine who said the same... I'm feeling optimistic that this new unit may fix it.
Of course they could send me 2 bad ones in a row I guess lol.
I wish I could get more info out of the employees, I know damn well they know whether this is an issue with the psu (quality control or otherwise) as well as what the limits are.
I have to believe if they are just giving Vince (kingpin) toys (4xtitans) to just play with and overclock to his hearts content on, then their are several other employees with a similar system who know through and through the load put out by this sort of rig and whether or not the nex can handle it.
Why the hush hush? Some tech support/enlightenment could do this thread some justice. I'm imagining the hundreds of people googling this issue only to end up here with no solution.
Abyways, thanks for the PMs and responses so far! Hands are tied till I get this new psu one way or another :(
klepp0906
2013/12/02 13:15:54
cerisettex That is what I get when pushing my system at 100%. Why there is ~300W powerloss, it's normal?? I have 245VAC outlet. I guess it's normal, when 2000W input => 1650W output, 1768W input => 1436 output, seems to be proportionnal.
Yes it's normal. Read up on how psus work. It's quite good relative actually. See that gold rating? It's called efficiency. What are u using to load it up? What kind of system?
cerisettex
2013/12/02 13:37:09
Thank you. Yes I know about efficiency and power loss, but just wondering to know if its normal after my previous faulty psu I'm a little bit stressed lol. My System : CPU : Intel Core i7 3930k 4,9Ghz Mother Board : ASUS Rampage IV Extreme X79 RAM : Corsair Vengeance 16Gb 1867Mhz Video Card : 3-way CrossfireX (Tri-Fire) MSI R7970 Lightning PSU : EVGA 1500W SUPERNOVA Watercooling : Corsair H100 Antec DF-85 Windows 8 Pro 64bits Some of my scores : 3D mark 11 : P24187 general, 33954 graphic score, 14439 physic, 11278 combiend 3D MARK NEXT 2013 ("old") Fire strike : P18376 general, 26715 graphic, 17083 physic, 5694 combined 3D MARK VANTAGE P64379 general, 72528 graphic, 48150 physic. Sorry web links isn"t appears in this forum so that's why I manually write my scores. I use OCCT, Power supply Test, it runs your systeme at 100%, all components EDIT : I'll buy Swiftech watercooling H20 220 EDGE and Gskill TridentX 16Gb 2400Mhz to improove my physic score in 3D mark 11
post edited by cerisettex - 2013/12/02 13:44:12
klepp0906
2013/12/02 13:47:46
Yep, if your psu has say... A 90% efficiency for example (very good, like the evga) you could basically take your input wattage and your output should be 90% of that. The rest is let's say, lost to the ages for lack of a lesson on electrons and such :p
So long as your rails are within spec, and your not experiencing shut downs under load, you should be AOK, don't even stress about it
cerisettex
2013/12/02 13:54:40
Thank you :) Yeah, all seems be working now after receiving new 1500W nex :) About your psu, if it's still shutdown, try to find second psu (maybe your friends can give you) just to provide power to your cpu and motherboard and running your 1500W evga with titans. If your pc still shutdown, defenitly powersupply issue. :'(
cerisettex
klepp0906
2013/12/04 08:45:57
new one arrives tomorrow so we shall see what happens. ill keep ya's posted. Anyone in this thread have a Kill-a-Watt MainMeter AND a NEX1500? If so, please post. I have a small request I thnk the entire community will find useful/appreciate!
cerisettex
2013/12/04 18:51:27
Ok :) It's RMA replacement or 2nd 1500W? 'Hope it's second 1500W because only 1500W isn"t enough for you :(
FalconX79Dark
2013/12/04 20:45:35
EVGA X79 Dark/EVGA GeForce GTX 1080 FTW Hydro Copper in SLI/Caselabs Black Magnum M8/Lamptron FC5 V3 Fan Control/I7-4930K/ Raystorm Copper CPU block/Twin D5 vario pumps with Dual Bay Reservoir/XSPC glass Photon Tube Reservoir 270mm/AX Triple Radiator/32 Gb G.Skill DDR3-2400 CL10-12-12-31/ Samsung 850 Pro 2 Tb/EVGA SuperNOVA 1200 P2 Power Supply/Win 10 64/ ASUS ROG Swift PG278QR 27" G-SYNC 165Hz Gaming Monitor 2560x1440, 1ms, 1,000:1| EVGA Nu Audio Pro 7.1 Sound Card/Razer Nommo Pro 2.1 THX-certified speakers/Razer Tiamat True 7.1 gaming headset.
