Helpful ReplyMax Safe Mesh Voltage?
jasoncodispoti
  • Ribbons : 14
2019/08/09 14:38:29 (permalink)
Anyone happen to know what the max safe Mesh voltage for X299 is for everyday? From what I am seeing looks like you are good to take it all the way to 1.3v.
Motherboard - X299 Dark
CPU - Intel 07-9800x
Thanks!
Intel Core i7-9800x | EVGA X299 Dark| EVGA RTX 2080ti FTW3 Ultra HydroCopper | 32GB Corsair Dominator Platinum | EKWB Liquid Cooled Loop | Phanteks Enthoo Primo SE | EVGA SuperNOVA 1000 P2
  • Ribbons : 122
Re: Max Safe Mesh Voltage? 2019/08/09 15:13:17 (permalink)
https://xdevs.com/guide/e299ocg/
look 1/2 to 2/3 down the page for different Voltages
Mesh @ 4/5 way down the page
post edited by Cool GTX - 2019/08/09 15:19:16
a213m
  • Ribbons : 20
Re: Max Safe Mesh Voltage? 2019/08/09 15:13:21 (permalink) ☄ Helpfulby Cool GTX 2024/01/17 09:55:25
My free and open source SDR-DDR5 SPD reader/writer with write protection capabilities
New: 13900K, Z790 HERO, 2x32GB 6800C32, 4090, 2TB SN850, AX1600i
Old: 10980XE, X299SE2, 8x8GB 4000C15, 4090, 2TB SN850, AX1600i
jasoncodispoti
  • Ribbons : 14
Re: Max Safe Mesh Voltage? 2019/08/09 17:45:06 (permalink)
I had viewed the suggested 1.1v and 1.25v that were mentioned in that article as starting points (1.1v) and what they found to be stable (1.25v) for there OC, not necessarily MAX voltage.
Thanks though as it does give a good frame of reference.
jollydet
Re: Max Safe Mesh Voltage? 2019/08/09 20:08:08 (permalink)
Mesh and vccio being to high are the first things to degrade your cpu, i can get 32 mesh with 1.15v on my 7960x, anything higher requires way more voltage and makes little sense to me. What kind of frequency/voltages are you guys seeing on your chips?
bruno_ro
Re: Max Safe Mesh Voltage? 2019/08/09 23:07:50 (permalink) ☄ Helpfulby Cool GTX 2024/01/17 09:49:57
Mesh voltage contributes to CPU heat, so chek your CPU temp and increase/decrease it accordingly.
