Re: Lost power from "perf" port on 850 p2
2021/04/20 13:21:34
I'm running into the same problem still, as of late more often. Now that I have alerts and sounds on to check and make sure there is more then 1 rpm on the pump, it seems that upon system wake up is when the power is not getting applied. I have HWInfo set that after 20 samples if it's still reading a zero rpm, to alert, play a sound, and shutdown the system. This is how I know it seems to stem from a wakeup from sleep problem. If the system fires up and power is applied, the system runs all day long with no issues of losing power to the pump. I did as you suggested and now I have the harness plugged into SATA 3, the pump plug is connected to the very first molex connector on the harness, and everything is working as I type this but it's been less then 20 minutes and as I've found out, will have to wait to see what happens after a wake from sleep event, or rather several of the next week or so.
I'm curious as to why you wanted me to try a sata port to power the pump? Is there any logic inside the power supply that's different perhaps?
Thanks!
