Little uneasy to start using my replacement card (RTX 2070 Ultra)
scot_mel
2018/11/21 13:48:49 (permalink)
Hi all,
I just went through the RMA process and got a replacement RTX 2070 here. I still haven't opened it but after reading more people having issues with just the 20X0 series in general... I wanna know what can I do to protect myself in case the replacement (brand new card) goes out.
I mainly wish to know what's different with any problems I may encounter using this card.  Does that mean all replacement/warranties still apply to this card? Do I have to register this card as well?
Thanks.
3 Replies Related Threads
    Re: Little uneasy to start using my replacement card (RTX 2070 Ultra) 2018/11/21 13:57:38 (permalink)
    Your 3 year warranty carries over to the new card, so you're completely covered, and you'll be able to rma again if needed.
    scot_mel
    Re: Little uneasy to start using my replacement card (RTX 2070 Ultra) 2018/11/21 13:58:14 (permalink)
    Awesome that's all I wanted to double check, thanks for the quick response :)
    Re: Little uneasy to start using my replacement card (RTX 2070 Ultra) 2018/11/21 13:59:09 (permalink)
    No problem.
