Led question for Water cooling 1070ti ftw 2 with icx cooler
ethantanious
2019/05/28 14:56:03 (permalink)
I have the 1070ti ftw2 with icx cooler and I'm looking into doing a full custom water cooling loop but I'm curious exactly how the rgb lighting connects to the PCB and if it is at all possible to retain the g p m lights as well as have the customizable rgb after removing the stock cooler? The only water block I was able to find in stock was a byski that does have 5v rgb lighting... But is it possible to connect that rgb directly to the pcb and this control it via pxoc? Does evga have a standard rgb connector on the board? if so is it 5v or 12v? Any information is greatly appreciated.
0 Replies Related Threads
