Laptop Battery replacements, help
christinalevinee
2018/02/06 02:49:37 (permalink)
I have a HP DV3510nr . Yes its an older laptop, but works just fine for what it is. Well, the battery just died, to where the system doesn't even recognize it. I started looking for batterys, and it seems they are sketchy at best, saying refurbished, new HP, but with different number etc.
Is there a genuine place that sells solid batterys for laptops you recommend.
Thanks
4 Replies Related Threads
    • Ribbons : 270
    Re: Laptop Battery replacements, help 2018/02/06 03:16:00 (permalink)
    This is "Computer Industry News"?  I think you meant to post this question in "General Hardware".
    • Ribbons : 84
    Re: Laptop Battery replacements, help 2018/02/06 08:06:19 (permalink)
    https://www.laptopbatteryfactory.com/hp-dv3510nr
    This battery has a 1 year warranty
    • Ribbons : 282
    Re: Laptop Battery replacements, help 2018/02/06 09:25:17 (permalink)
    $19 here Link
    arlenewei
    Re: Laptop Battery replacements, help 2018/11/11 18:26:43 (permalink)
    All laptop batteries are built to handle a certain number of charge cycles, usually somewhere around 500 full cycles — and sometimes even more. Essentially, a charge cycle equals one full discharge down to zero percent and then a recharge back up to 100 percent. A discharge down to 50 percent and then back to 100 percent would equal half a cycle. Over time, each charge cycle decreases a battery’s capacity from its design specifications, meaning that the fewer times you drain it, the longer the battery last — all other things being equal.
