LockedLED Sync Issues
TazX14
2019/08/07 05:29:11 (permalink)
Not sure where to post this, so I've posted it here and in the clc forum in hopes of getting an answer (sorry for double post). I have a 2080ti FTW3 gpu and clc 260. Unfortunately I cannot get the led sync to work for them. While my gpu has been saved, my clc resets to the rainbow setting every reset. Even then getting it to change to a static red is kinda troublesome as led sync tends to be finnicky and only works sometimes. Can anyone assist with this as it's driving me a bit nuts?
1 Reply Related Threads
    • Ribbons : 282
    Re: LED Sync Issues 2019/08/07 05:53:19 (permalink)
    You only need One Thread LED Sync Issues for your Question, if need be the Thread will be moved by an EVGA Forum Moderator.
    [FAQ] EVGA Forums Terms of Use
    post edited by bcavnaugh - 2019/08/07 05:58:31
