Carmen813
Just curious if anyone sees >500w on their Kingpin with the ln2 bios. Highest I've seen is around 485 in Timespy Extreme. This is with 100mv/100core/1000 ram.
TsBForsaken
Re: Kingpin LN2 power draw
2021/04/15 11:31:13
magillaman
2021/04/15 11:54:16
christobol
2021/04/15 11:57:22
Is it possible to tell which version of the bios you're running in windows? I haven't seen my power go beyond 450 on the LN2 switch.
Please consider using my Associate and Rewards codes to save 3-10% off your next EVGA purchase
magillaman
2021/04/15 12:03:31
I was running the 1000w KP bios
christobol
2021/04/15 12:09:06
magillaman I was running the 1000w KP bios
How do you know that's what you were running other than flipping the switch? GPUz looking at the bios number? Mine is showing: 94.02.42.C0.0C Which doesn't show up on Tech Power's DB VGA Bios Collection | TechPowerUp
post edited by christobol - 2021/04/15 12:11:45
christobol
2021/04/15 12:12:27
Oh and I'm not home to flip my switch to see what bios rev I'm getting on the other switches
magillaman
2021/04/15 12:26:15
Open GPUZ, go to the Advanced Tab.. Choose Nvidia BIOS from the drop-down. That will show build number, power limits etc..
christobol
2021/04/15 16:42:23
magillaman Open GPUZ, go to the Advanced Tab.. Choose Nvidia BIOS from the drop-down. That will show build number, power limits etc..
Ah yeah there we go. Mine is limited to 520. I wonder if I'm just on the XOC rather than LN2 bios. Just to be sure, a newer bios hasn't been released right?
Carmen813
2021/04/15 18:06:44
Max mine will hit is 495. That is in Time Spy Extreme, overclocked (100/1000+100mv)
magillaman
2021/04/15 18:16:49
KP default Bios(es): LN2 - 520w OC - 480w Default - 450w
EVGA has updated all 3 with ReBAR support. - do it through Precision X1
All of those bioses are limited and have protection enabled.. The 520w XOC and 1000w KP Bioses do not.
- Ribbons : 270
2021/04/15 18:33:05
christobol
XOC BIOS is greater than LN2 BIOS. You are probably "just on" the LN2 BIOS rather than the XOC BIOS. Why does EVGA call the default limited overclocking BIOS a LN2 BIOS? Good question. Confusing, huh?
talon951
2021/04/15 19:05:19
Seems like you would know if you're on the KP XOC bios since it has to be flashed manually AFAIK.
Ty, just flash the 1kw bios to the LN2 slot and then it will be labeled correctly. Lol
christobol
2021/04/15 20:10:55
talon951 Seems like you would know if you're on the KP XOC bios since it has to be flashed manually AFAIK.
Where do you get the 1k bios? Is that the one where you email Vince? magillaman KP default Bios(es): LN2 - 520w OC - 480w Default - 450w
Ah that's what I've got on my card still then, so I'm just running stock. Makes sense why I haven't seen over 500 since you rarely hit the power limits.
christobol
2021/04/15 22:40:36
So learned something neat, you can change the bios that's running without rebooting. The card will tell you on the OLED that it's changed the bios. Pretty sweet! I'm getting a max of 565 watts while in Port Royal. Where can I download the xoc bios? I think I'm getting power limited.
- Ribbons : 270
2021/04/16 03:47:37
christobol So learned something neat, you can change the bios that's running without rebooting.
I don't think that is true. I think that the card can tell you which BIOS is selected, but I don't think that the new settings are used without a reboot.
degenerate
2021/04/16 06:40:39
I very frequently hit the 520W power-limit when playing modern games @ 4k. Need an official 600W+ bios that is gaming-optimized and doesn't void warranty.
|5900x|MSI B550 Unify-X|2x16GB G.Skill 3800 C14 @ 1900 FCLK|2TB WD SN850 M.2|EVGA 3090 KPE|EVGA 1600T2|Alienware '25' & LG 48" CX OLED|
christobol
2021/04/16 09:44:42
I didn't think it would work either... and was rebooting between checking the power limits of each bios and only flipping the switch when off. Then thought I'd do it while it was on and WOAH! A transition graphic popped up that shows a unique gif depending on which switch you move to, and it says Activated OC or Activated LN2. So going back into GPUz all of a sudden the power limits had changed to match whatever setting I was on. So I went from booting off the stock bios, to the LN2 with a switch flip without rebooting, then ran a benchmark and was pulling 565 watts.
