jenkeeez
I can run this card on +200core and 1650mem in PR and I got 15389 score on stock cooler , but when I game I cant get it to be stable on more than 70 core , Please give me advice on what to do , I play cold war on 2k 240hz , and I can use classified tool if I have to , I really want to know the limit when gaming your help is really appreciated Thanks
saygin123
Re: KINGPIN owners need help with my overclock
2021/01/24 10:19:10
wow its a big difference usually i can run the card +210 core on becnhmarks and +175 on games and stable but your difference is alot
Kevin115
2021/01/24 10:23:42
Can you share some thermal information? How cool your card is running? Thermal has significant impact on stability when OC.
jenkeeez
2021/01/24 10:37:50
When I'm in game highest Temp was 55C , are you using Classified Tool ?
Kevin115
2021/01/24 10:42:51
jenkeeez When I'm in game highest Temp was 55C , are you using Classified Tool ?
Sorry. I'm not a KP owner. Can't help you. But I think this information might be useful for the people who have the knowledge to help you.
SoldierRBT
2021/01/24 15:01:45
What bios are you using? Are you running +1650 mem in games? Lower that to +1000 or +800
ds760
2021/01/24 15:22:19
Run a test in px1 and see what you get. Benchmarks are one thing stable oc in games totally different. I can run for hours without crashing in some games at +1200 mem and never crash at +200. Trial and error. The good starting point is whatever px1 passes at.
_Gir_
2021/01/24 15:30:14
Probably as expected. Kingpin is already factory overclocked so to say a +500 or +100 OC is already on top of an OC. The 3090 double sided memory design combined with the hybrid cooler makes the card a different kind of challenge to keep the heat away during extended use at peak clocks. I've had to turn down my OCs for gaming stability even though I can run short benchmarks at a more aggressive OC all day. Plus things like if the game is rasterized only vs RTX can also challenge the stability of an OC. Nice score in PR btw.
crowie03
2021/01/24 16:35:20
On stock bios I can achieve Port Royal score of 15110 and consistently low 15k with 133 on core and 1350 on memory. This is with the card in case and cooler outside of case. Anything above those clocks and it will crash in Port royal. With ambient temperature of 28 celcius with card and cooler in case my score drops to 14750. Im using the h500p mesh case and 360 gpu rad mounted on top of case.
crowie03
2021/01/24 16:48:00
kraade
- Ribbons : 7
2021/01/24 17:25:37
Game stability vs overclocking benchmarks are way different, Benchmarks are a Drag race that only have to handle the load a few minutes, Overclocking for a game in which you load the GPU for over an hour tweek your settings and its going to be like 200 Memory and 100 on the GPU clock, Use MSI Kombuster and walk and check it every 20 minutes, Go away for 2 hours and see how your system is doing . then you have a stable overclock, this is the same thing if you have a 3090 KPE or a 1050ti...
Dabadger84
- Ribbons : 10
2021/01/24 17:26:58
Keep in mind, Kingpin dies are pre-screened, if you can't maintain at least 2100MHz rock stable on the core in games/benchmarks, something is definitely wrong, that's what they're pre-selected to be able to do bare minimum. Most people I've seen are hitting ~2200MHz or a bit less before they actually have to start futzing with the Classified Tool, from what I understand. My card will be here tomorrow, should be interesting. The base clocks on the Kingpin are 120MHz higher than a 3090 FTW3, so keep that in mind when comparing offsets with people, your +75 is a higher clock than their +165 in actual boost clocks as a result. As a reference for that, my 3090 FTW3 Hybrid, without any overclock/offset, hits 1905-1935MHz on the core - pretty sure Kingpins start off in the 2040-2070MHz range, right? kraade Game stability vs overclocking benchmarks are way different, Benchmarks are a Drag race that only have to handle the load a few minutes, Overclocking for a game in which you load the GPU for over an hour tweek your settings and its going to be like 200 Memory and 100 on the GPU clock, Use MSI Kombuster and walk and check it every 20 minutes, Go away for 2 hours and see how your system is doing . then you have a stable overclock, this is the same thing if you have a 3090 KPE or a 1050ti...
And yes, this. Games can be as or more stressful than some benchmarks, and you're running games for much longer than any benchmark. If you want to ensure stability on a GPU OC for 24/7 use, you should be running it through the ringer, Port Royal, both Time Spys, even all 3 Fire Strikes if you can, and multi-hour gaming sessions with games that both do & do not have RT stuff, Cyberpunk 2077 is a great stress test if you have it, turn off the frame rate cap & just let it eat - if it crashes during any of that, it's not stable, simple as that. On my 3090 FTW3 Hybrid, I run 2040MHz @ 1000mV (an overclock/undervolt) and get cooler temps, better than stock performance, and lower power draw, all in one package, it's quite nice.
post edited by Dabadger84 - 2021/01/24 17:29:19
jenkeeez
2021/01/24 21:44:12
I use +600 on the mem , will using frequency curve give me better stability ?
SoldierRBT
2021/01/24 21:57:28
Offset OC is better for gaming because internal clocks are almost identical to the requested clocks. You haven’t mentioned your clocks and temperature while gaming.
jenkeeez
2021/01/25 06:17:48
My temp is 55 max it drops to 35 between games, Highest stable clock is 2085-2070 , i use ln2 bios
jgalb21
2021/01/25 07:27:33
I need some help as well. My best Port Royal is 14231 with the Stock Bios, 105% power limit, +140/1200. Tried switching to the OC bios and LN2 bios and neither of them game me higher scores.
SoldierRBT
2021/01/25 08:22:21
jenkeeez My temp is 55 max it drops to 35 between games, Highest stable clock is 2085-2070 , i use ln2 bios
Make sure power and voltage slider are set to max. What’s the power draw? You may be hitting power limit and it drops your voltage which would lower the sustain clocks.
jenkeeez
2021/01/25 10:45:51
I will record power draw and come back to you ,Thanks
tresnugget
- Ribbons : 5
2021/01/25 12:06:10
Call of Duty games are not very overclock tolerant. Only game worse is cyberpunk. I use CoD gamee to test stability for my 24/7 overclocks. BO4 with my 2080 Ti would only do like +45 whereas most other titles would do +120. That's one hell of a card you have. You can go way higher in PR than I can. But your CoD OC is identical to mine.
Clovis559
2021/01/25 15:17:16
Yeah Cyberpunk was the worse for me. I thought I had it rock stable after gaming for hours, then I walk across the nomad camp and it crashes in 20 seconds.
tresnugget
- Ribbons : 5
2021/01/25 16:21:25
Clovis559 Yeah Cyberpunk was the worse for me. I thought I had it rock stable after gaming for hours, then I walk across the nomad camp and it crashes in 20 seconds.
I ended up giving up on cyberpunk. I was stable for hours at +100 on my kpe, then the next time I played I'd crash immediately. Closed all background apps and it lasted a few more hours then crashed. Got down to +75 and still eventually crashed. Haven't crashed yet on no oc but thats not been long.
ds760
2021/01/26 08:59:09
Cyberpunk crashes a lot at the best of times. Don't use it to decide whether you're stable or not.
