Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra?
platysaur
2021/09/04 11:46:47 (permalink)
I saw a post on Reddit pertaining to the 3000 series cards saying not to daisy chain your power cables. Obviously based on the title I don't have a 3000 card. I have a 2070 Super, and for about a year and a half I have used a single power cable on it. Is that ok? I don't have any problems with stability at all or running games, but I don't want to start a fire or something. I don't have another power cable right now. My PSU is a Corsair RM (2019) 650 W 80+ Gold Certified, if it helps.
6 Replies Related Threads
    • Ribbons : 270
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/05 05:11:20 (permalink)
    The cable came with the PSU and the cable and PSU are designed for that purpose. It's been working fine for 1.5 years. Don't worry about it.
    The 3000 serious are so fragile, everyone is blaming everything.
    • Ribbons : 115
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/05 12:50:53 (permalink)
    Single line is always the most practical. Veering off the cable to handle one more piece of hardware is ok though. Try not to hook up more than two on that line.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    • Ribbons : 84
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/06 10:11:34 (permalink)
    The rule is: Don't daisy chain!
    AlanBlayney
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/07 03:58:40 (permalink)
    TDP of that card is ~200 W.
    8-pin PCIe VGA power cables are rated for 288 W spread between all connections. I think each individual connection is good for up to 150W.
    As long as you're using the cables that came with your GPU or from another reputable source, you should be totally fine.
    For that card, I'd only worry if there was some risk that the cables weren't up to spec, or if I was overclocking with exotic cooling.
    https://www.gpuminingreso..s.com/p/psu-cables.html
    8086K / 3080 Hydro / 2x8GB T-Force Nighthawk 3600MHz / Samsung 870 Pro 500GB / Z370FTW / Super Flower Platinum SE 1000W / DG77 wall-mounted
    BiggyNewton
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/08 08:18:23 (permalink)
    I wouldn't worry about it if you have had no problems.  I ran a 2080ti with one cable for a long time and it was fine.  Really depends on your PSU and generally I don't do it but I just forgot about it honestly.
    Associate code: EKA5I8R4C7M401L
    Thanks to anyone using my code!
    BizSAR
    Re: Is a daisy chain power cable ok for EVGA 2070 Super XC Ultra? 2021/09/08 11:30:31 (permalink)
    I've always read that while using a single cable might be ok, it's best to use two different ones.
    BizSAR
    EVGA 3090Ti FTW3 Ultra / ZOTAC 4070Ti Trinity OC - ASUS ROG PG279QM
