Patroy
Hello, i've got 2x GTX 660 in my PC and i have to say that when i hadn't these cards, my computer was totally noiseless when temperatures was low. Now i'm trying to reach this point with cards installed but these fans are quite hearable which isn't as cool as noiseless PC. Can I totally turn it off in low level of GPU temperature? Evga precision doesn't provide me that possibility.
mojman2001
Re: Is There any way to turn off graphics fans when there's low GPU's temperature?
2014/09/27 15:12:29
Lol really dude the cards run hot they need fans to cool them off. If your wanting something that noiseless then get yourself a low end card that is fanless or build a water cooler or dont sli your 660.
Kevsta97
2014/09/28 00:08:57
Your graphics cards have fans for a reason, to keep the cool. Without the fans on, your GPU's can overheat and possibly completely destroy the card. Although you may prefer low noise, fans are a necessary part of a graphics card. You can also install a waterblock for your 660's if you want to go through all the trouble of making your system water cooled. Or you can just live with the fan noise. EVGA Precision X should allow you to be able to lower your fan speed to 30%. Just tick off the option "Auto." I have a GTX 660 SC myself, I can barely hear it. I
CPU: Intel Core i5-4690k @ 4.7 GHzCPU Cooler: Corsair Hydro Series H50GPU: EVGA GTX 660 SC EditionCase: Corsair Carbide Series 300r Windowed Edition PSU: Corsair HX 750W Motherboard: MSI Z87 G45 Ram: 2x4GB G.Skill, 1x8GB HyperXSSD: 256GB Corsair Force LX Series SSD HDD: 3x300GB Seagate @ 7200RPM Monitor: 2x 1900x1200 HP Monitors @ 5ms Mouse: EVGA Torq X10 Gaming MouseKeyboard: Razer Deathadder
FUSIONCHA0S
2014/10/03 13:23:40
If noise is an issue, i would recommend removing the stock fan at your own risk and installing a quieter one. I installed a corsair closed loop system on mine, take a look at my setup. I can run my games at max and my fans are on low and more quite than the stock fan, and my temps are only around 40 compared to 60. There are ways around your issue, but it would be senseless and idiotic to completely turn the fan off.
- Ribbons : 270
2014/10/04 08:36:28
To answer your question directly, no matter which brand or model of fan you use, it is not possible to make it shut off if the fan is plugged into the video card's fan controller. The video card's fan controller has a hard set minimum PWM duty cycle and will never go down to 0%.
- Ribbons : 115
2014/10/04 10:35:50
As long as the computer is on, the card will generate some heat. The GPU and CPU need a fan to keep the temperatures down.
_JamesR
2014/10/04 19:42:47
Unfortunately, that is not an option for older cards, as not just the firmware needs to support it, but also the motor for the fans themselves. However, for our GTX 970s with ACX 2.0, we do offer a vBIOS update that can do exactly that -- the fans stop until the card itself needs to be cooled, at which point they enter the fan curve and spin up as necessary.
EVGA Z97 Classified w/ i7 4790 | 32GB Crucial Ballistix Elite | 2x EVGA GTX 980 Ti ACX 2.0 | EVGA 1000w G2 | Samsung EVO 840 120GB | Samsung 850 EVO 250GB | Seagate 3TB | 3x WD 2TB (Raid-5) | Corsair H100i GTX | 3x Asus VS278P-Q 27" 1080p 1ms GTG monitor (surround) | 1 Monoprice 28" 4K 5ms GTG (accessory)
WgregB
2014/10/04 21:37:15
Turn the music UP!
ASRock P67 Extreme6 - i5-2500k G-Skill Ripjaw 1600 -16GB OCZ Vertex 4, OCZ Agility 4, Seagate Momentus XT ST750LX003 Hitachi GST Deskstar 2 TB - Storage2-GTX 460 SLI Thermaltake Toughpower 750W
Gomez99
- Ribbons : 14
2014/10/05 00:24:28
JoeBroniee
2014/10/05 01:51:53
get ref amd r9 290 cards, sounds like a jet.
Ncase M1, Asus M6impact intel i5 4690k HyperX Genesis EVGA GTX770 Silverstone sx600g Samsung 840EVO
- Ribbons : 84
2014/10/05 03:11:59
Nattius
2018/07/13 18:01:52
I have an artic accelero xtreme IV in my evga gtx 1080 sc, and when I configurate with msi afterburner fans to 0 %, the fans continue spinning about 655 RPM. It´s very quiet, but stiell I can hear them
Hoggle
2018/07/13 18:15:31
Really you would want the fans spinning. It shouldn’t be that loud when you are not really putting much graphic workload on them though.
Nattius
2018/07/13 19:13:46
I would like to configurate the fans to 0% until 51 grades like I could make with the stock cooler, but now with the artic accelero xtreme IV, I can´t do that, from 0% to 17% is always spinning to 650 RPM. What I mean if am only using word and internet, I don´t need/ want any noise
- Ribbons : 270
2018/07/16 00:39:17
Nattius I would like to configurate the fans to 0% until 51 grades like I could make with the stock cooler, but now with the artic accelero xtreme IV, I can´t do that, from 0% to 17% is always spinning to 650 RPM. What I mean if am only using word and internet, I don´t need/ want any noise
Sorry. Too bad. The hardware does not allow it.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2018/07/16 08:25:43
Hardware doesnt support it. If you upgrade to a newer gen gpu that does support this, then it is possible.
Also, dont be afraid to create a new thread. This thread was dormant for almost 4 years before you revived it :-)
bdary
- Ribbons : 116
2018/07/16 08:26:50
If you have the money you could get yourself a 9xx or 10xx series GPU that has the 0db feature. The fans only kick in when you hit ~60C. You would most likely get better performance from any of the higher end cards from those series than your current 660's combined.
Nattius
2018/07/16 11:50:02
Sorry, I forget saying that I have an evga gtx 1080 sc.
- Ribbons : 270
2018/07/17 23:02:08
bdary
- Ribbons : 116
2018/07/18 06:53:05
