Jur1995
Hello people, I just purchased the EVGA GeForce GTX 770 SC W/ ACX Cooler and when I installed my GTX 770 on my Intel motherboard, I can't boot Windows. First my motherboard got a 5A code. 5A = Resetting PATA/SATA bus and all devices. And when that was done (I didn't do anything), I got a black screen with a white 0_ in the right bottom corner. My motherboard already has the newest BIOS (BGP6710J.86A.2209.2012.0717.2302). This BIOS is from 07/17/2012 version 2209. This are my system specs: Motherboard: Intel DP67BG CPU: i7-2600 GPU: EVGA GeForce GTX 770 SC /W ACX Cooler RAM: Kingston ValueRAM 8GB DDR3 1333 MHz PSU: Nexus RX-7000 And the GPU is tested on other Intel motherboard chipsets with the newest BIOS (chipsets: P67, Z68 and Z77). I think my GPU is broken.
post edited by Jur1995 - 2013/07/11 03:24:50
Jur1995
Re:Intel DP67BG motherboard with EVGA GeForce GTX 770 SC W/ ACX Cooler (Doesn't work?)
2013/07/11 04:16:24
Can anybody help me, please?
Wreck3r
2013/07/11 05:58:41
I have the same config as you but I can get into windows. I cannot see anything between BIOS menu and windows login screen. I think you should contact support for the updated VGA BIOS.
Jur1995
2013/07/11 06:04:05
coolmistry
- Ribbons : 45
2013/07/11 06:08:24
Jur1995 Hello people, I just purchased the EVGA GeForce GTX 770 SC W/ ACX Cooler and when I installed my GTX 770 on my Intel motherboard, I can't boot Windows. First my motherboard got a 5A code. 5A = Resetting PATA/SATA bus and all devices. And when that was done (I didn't do anything), I got a black screen with a white 0_ in the right bottom corner. My motherboard already has the newest BIOS (BGP6710J.86A.2209.2012.0717.2302). This BIOS is from 07/17/2012 version 2209. This are my system specs: Motherboard: Intel DP67BG CPU: i7-2600 GPU: EVGA GeForce GTX 770 SC /W ACX Cooler RAM: Kingston ValueRAM 8GB DDR3 1333 MHz PSU: Nexus RX-7000 And the GPU is tested on other Intel motherboard chipsets with the newest BIOS (chipsets: P67, Z68 and Z77). I think my GPU is broken. Have you try test other system pc? Try remove card then reset your CMOS BIOS then try insert new card so try test boot up? Post us back if still problem
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
Jur1995
2013/07/11 06:11:44
The card is tested on different Intel motherboards: P67, Z68, Z87 chipset. Z77 is a mistake.
- Ribbons : 84
2013/07/11 06:29:46
I have asked EVGA if they can review this thread
JoeyC
2013/07/11 06:43:13
Jur1995 How can I contact them? Good morning Jur1995, I am sorry to hear about the issues you are having, I will be sending you an email in a few with instructions on how to resolve this. If you have any other questions feel free to contact me directly or post in this thread (JoeyC@evga.com). Have a nice day
Wreck3r
2013/07/11 06:49:03
I am also waiting on EVGA support to find a solution as I mentioned I have an identical problem. The only difference is that I can get into windows (win 8 x64) but I cannot see anything between the first BIOS screent with Intel logo and the windows login screen, not splash screen. The only visible thing is "0_" a the bottom left of the screen. Any info from support or the elusive C3 BIOS would help us both. Regards
Wreck3r
2013/07/11 06:51:04
EVGATech_JoeyC Jur1995 How can I contact them? Good morning Jur1995, I am sorry to hear about the issues you are having, I will be sending you an email in a few with instructions on how to resolve this. If you have any other questions feel free to contact me directly or post in this thread (JoeyC@evga.com). Have a nice day Please add me also to the recipients address as I am in the same boat. Regards
JoeyC
Jur1995
2013/07/11 06:54:24
If the problem is the firmware of the EVGA GeForce GTX 770 SC ACX, I can't flash it. I think I have to send my GPU back to you. BTW, I have bought this GPU via So, I live in The Netherlands.
JoeyC
2013/07/11 06:57:34
Jur1995 If the problem is the firmware of the EVGA GeForce GTX 770 SC ACX, I can't flash it. I think I have to send my GPU back to you. BTW, I have bought this GPU via So, I live in The Netherlands. Not a problem I will work with our EU office to assist you with a replacement.
- Ribbons : 84
2013/07/11 06:57:36
Jur1995
I live in the Netherlands and if you wish I can assist you with the flashing of your card if you don't live too far from me
Jur1995
2013/07/11 07:01:02
Oké. Waar woon je? Ik woon in Limburg. Mijn stad is Venray.
Jur1995
2013/07/11 07:06:57
@EVGATech_JoeyC, how can I send my GPU back to EVGA? I bought it in The Netherlands via a webshop. I think I have to send my GPU back to that webshop (azerty.nl) and that Azerty sends it back to EVGA. P.S. Sorry for my (not so really good) English.
post edited by Jur1995 - 2013/07/11 07:12:41
- Ribbons : 84
2013/07/11 07:08:23
On the Forums you have to speak English. I will send you a PM in English. Jur1995
Jur1995
2013/07/11 07:14:25
@rjohnson11, that is too far away, sorry.
Jur1995
2013/07/11 07:42:50
rjohnson11 On the Forums you have to speak English. I will send you a PM in English. Jur1995 Oké. Waar woon je? Ik woon in Limburg. Mijn stad is Venray. Okay, sorry for that.
JoeyC
2013/07/11 07:56:09
Jur1995 rjohnson11 On the Forums you have to speak English. I will send you a PM in English. Jur1995 Oké. Waar woon je? Ik woon in Limburg. Mijn stad is Venray. Okay, sorry for that. -Jur1995 I have sent email to our EU office regarding this issue. Please allow a business day for them to follow up with you. If you have any other questions feel free to contact me directly. Have a nice day
Jur1995
2013/07/11 07:58:41
I send my EVGA GeForce GTX 770 SC ACX back to the webshop where I purchased it.
JoeyC
2013/07/11 08:14:29
Jur1995 I send my EVGA GeForce GTX 770 SC ACX back to the webshop where I purchased it. I would recommend working with the EU support agent who recently emailed you. Exchanging the video card at the shop will most likely result with the same issue. Doing a RMA directly with EVGA will ensure that your video card is update to ensure compatibility with your motherboard.
EVGATech_ChrisB
EVGA Tech Support
2013/07/11 09:30:46
I am posting for anyone that maybe visiting this thread to try and find a solution for your motherboard not displaying a post screen properly with your GTX 770 or GTX 780 Graphics card. I can confirm that some motherboards may require a compatibility update for the firmware on the GTX 770 or GTX 780 graphics card. If you should need this update please email support@evga.com with the EVGA part number of the card in question and request the compatibility update. Once your email is received we will email you the update for your card to assist. Thank You, Chris Bencivenga chrisb@evga.com
