card is a 2080ti xc hybrid , does someone have pictures of what needs to be connected to where and how exactly is this mod supposed to be done, my cable will be arriving soon, and im not entirely sure what header i need to disconnect on the the card, also, where do you thread this wire through ? is there a gap small enough between the two 8 pin connections ? ive head that even lowering to 90 percent pump speed does eliminate the coil whine ?
