Hot!Individually Sleeved Cables for EVGA G5/G2/G3/GM/GP/PQ/P2/T2 Power Supplies
Page: < 12345.. > >> Showing page 5 of 10
Aklorian
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/03 10:01:12 (permalink)
Couple days of searching and I still can't find any concrete confirmation. I'll let you know if I find anything though!
Pgcmoore
  • Ribbons : 14
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/03 11:38:17 (permalink)
Aklorian
Read this , posted today!
Looks like some GS owners may have an option soon!!!
"if this is true"
post#8   all the way at the bottom
http://linustechtips.com/...-cables-compatibility/
post edited by Pgcmoore - 2015/08/03 13:32:57
   "This program has performed an illegal operation and will be shut down"
                        My Affiliate Code is  05G-UGD-GZVU
Squall_Rinoa86
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/03 11:47:46 (permalink)
Ordered a White entire set from NewEgg for my G2 1300. Should be here tomorrow to finish out my looks for my computer. Took me nearly 7 months.
post edited by Squall_Rinoa86 - 2015/08/03 12:11:59
PSU: EVGA SuperNOVA 1300 G2
My Affiliate Code: AN1FW0VMG6
Don_Francisco
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/04 05:46:34 (permalink)
What type of sleeving do the cables have? Is it Paracord or nylon?
tonyforce36
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/13 02:49:54 (permalink)
Are the white P2 cables compatible with the New Supernova 850 P2?  The overview says it compatible to G2/T2/P2 however when you go to the compatibility tab the Newer 650/750/850 P2 are not listed.
http://www.evga.com/Produ...aspx?pn=100-CW-1300-B9
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/13 03:37:25 (permalink)
tonyforce36
Because they are new models and probably didn't change compatibility list.
http://www.evga.com
http://www.intel.com
http://www.nvidia.com
https://watercool.de
http://www.lian-li.com
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/14 09:34:11 (permalink)
I made some picture with EVGA Sleeve cables because I set cables on place... but as always picture is bad...
I have no other choice... What to do when I'm poor and all money go on expensive components and than I feel sorry even fans to buy because I need for next upgrade... :)
I will borrow some camera
post edited by Vlada011 - 2015/09/08 02:31:38
http://www.evga.com
dc300000
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/21 12:07:04 (permalink)
Are these compatible with the EVGA SuperNOVA 1000W PS power supplies?  I want to say yes since the PS is pretty similar to the P2, but I wanted to be sure.
Pgcmoore
  • Ribbons : 14
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/21 12:20:05 (permalink)
unfortunately not,
however corsair may offer some that will work soon, according to the link i posted above, they are / will be making some for the GS and they may also be compatible with the PS
dc300000
post edited by Pgcmoore - 2015/08/21 12:45:31
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/08/22 04:10:45 (permalink)
I didn't know in first moment how to set cables on best way because I don't like to bend cables to much to fit in first hole with rubber grommets.
Special VGA cables... Than I leave cables to go outside from next big hole than VGA cables back inside through other hole with rubber under all other cables and up in graphic card.
And one Velcro keep them on place with cables 24pin, CPU, SATA, Molex,.... I will show you better on pictures with light.
http://www.evga.com
rcald2000
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/01 02:56:11 (permalink)
Are these cables compatible with the new EVGA P2 850 PSU?
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/01 03:30:48 (permalink)
Yes they are compatible with all P2 models.
http://www.evga.com
rcald2000
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/01 03:36:06 (permalink)
EVGATech_ChrisB
Hi,
I am very sorry for any inconvenience, but these cables will only work on the EVGA power supply models listed below.
  1. 120-G2-1300-XR
  2. 120-G2-1000-XR
  3. 220-P2-1000-XR
  4. 220-G2-0850-XR
  5. 220-G2-0750-XR
Thanks for the quick response.  I only ask because when this forum thread was stated, it was originally announced that they were compatible with all G2/P2 PSU's and then there was an amendment (above) that stated that they were only compatible with select models within the G2/P2 lines.  That addendum was posted in this thread: Thursday, April 24, 2014 8:18 PM.
- Rob
post edited by rcald2000 - 2015/09/01 03:38:55
Don_Francisco
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 08:04:40 (permalink)
So what type of sleeving material is used on these cables?
Is it paracord or nylon?
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 08:48:20 (permalink)
It's more like nylon.
http://www.evga.com
Don_Francisco
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 08:52:35 (permalink)
Vlada011
Thanks.
sipherous
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 11:59:22 (permalink)
Just got my cables in and installed them, however I don't know if this is an RMA detail or by desing. My 24 pin connector is missing a connector on the 18 pin power supply connection. I do have a 550GS so it might be incompatible although all other cables work. Here are 2 pic to show,
If these are wrong can someone direct me to how to RMA these, they don't have a serial number to add to my EVGA products List.
Pgcmoore
  • Ribbons : 14
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 12:34:25 (permalink)
thats normal, you are good to go! (550 G2) but you said GS? if there evga theY are only for G2-P2-T2 you better test the 24 pin for voltage / and all the others!
 if any other , they will not work, and you will / can burn up your stuff!!!
post edited by Pgcmoore - 2015/09/16 13:11:35
sipherous
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 16:26:55 (permalink)
Ya I looked through it, the 24pin wasn't sending the proper voltage due to GS having an extra pin, I'll probably upgrade the power supply anyways, getting to close to max load with the new GPU.
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/09/16 19:35:15 (permalink)
Hi, ask people here for best model depend how much power you need when you decide to upgrade.
You didn't know little earlier... EVGA 550 G2 get best possible Total Score 10 on test. Price difference is not so big.
EVGA sleeve Set is compatible with SF models G2/P2/T2 100% with other probably not.
http://www.evga.com
gremlich
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/10/19 14:50:22 (permalink)
I'm sorry, but the 850 G2 that I purchased (image belw) from EVGA has a 20-pin and 8-pin connector on the power supply side against the 24-pin connector on my motherboard. Your cloth covered 24-pin/24-pin ATX power cables will NOT fit a 24-pin (mobo side)/20+8-pin (pwr sply side) ATX connector on the G2-220-0850-XR despite your claim to the contrary for this particular cabling solution. What other solutions do you have?
post edited by gremlich - 2015/10/19 14:55:51
Pgcmoore
  • Ribbons : 14
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/10/19 16:06:54 (permalink)
gremlich
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/10/19 16:43:38 (permalink)
Pgcmoore
  • Ribbons : 14
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/10/19 16:45:47 (permalink)
gremlich
Pgcmoore
http://www.performance-pc...hite.html#!prettyPhoto
Grazi!
np, they also have some new basic kits ( 4 cable ) but not sure on compatibility or what you need
dark4181
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/11/23 16:50:56 (permalink)
Any way to get custom cables that will route easily to the hard drive mounts in my Define S?
CPU: Intel 5930K w/ Corsair H90
Motherboard: ASUS X99 Pro 3.1
GPU: EVGA GTX 980 TI ACX 2+
PSU: EVGA G2 850W
Boot: Samsung 950 Pro 512gb
Games: Samsung 850 Evo 1TB
Mass storage: Seagate Hybrid 4TB x3
Case: Fractal Design Define S
Steam: darthspastic
Origin (BF3): Dark4181
Heatware: dark4181
stevenli1966
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/12/04 17:00:49 (permalink)
Oh man these look so good. Going to be getting them when I buy a new psu.
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/12/05 03:36:14 (permalink)
Yes cables are excellent... Except better look they are much stronger, nicer and better than hand made sleeved cables because use less space on back side of PC and much nicer fit with HDD, Molex, etc...look more natural and I like that.
Hand sleeved cables use more space than fabric default PSU cables, these not...
All wires from PCI-E cables and Molex, SATA could be tight and not bigger than cigarette and fit everywhere...
I like that most, I don't like not natural look of cables, different colors of sleeve, fat wires, etc...
http://www.evga.com
dark4181
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/12/09 18:04:40 (permalink)
Can we get custom lengths? Doesn't look like these will be ideal with my Fractal Design Define S. Especially the SATA power cables.
PSU: EVGA G2 850W
Steam: darthspastic
Heatware: dark4181
Lamgwin
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2015/12/25 14:59:22 (permalink)
These are good, but I don't need the whole kit.
On your US site you have part number 100-CK-1600-B9 which contains some 6 pin and molex cables, I actually only need these.
The US site doesn't seem to ship to EU, or at least the checkout process wouldn't let me select EU address.
Searching the same part number on the EU site has no results, are these available in the EU or UK?
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/01/25 16:30:11 (permalink)
hey guys,
we got an account on the EVGA forums now and are in the process of getting it approved - if you got any questions in regards to us or our products feel free to ask them in here.
CableMod
