themlharris
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2020/10/04 07:05:17
Ugh wish these were cheaper
isaiahsix8
Re: Individually Sleeved Cables for EVGA G5/G2/G3/GM/GP/PQ/P2/T2 Power Supplies
2020/10/15 16:44:00
EVGA_JacobF Now in stock! Supports all EVGA SuperNOVA G2, G3, GM, GP, PQ, P2, and T2 power supplies.
Me likely. Definitely going to pick up a set of these for my final water cooled 3090 build.
-Will Aorus Master z490i711kEVGA RTX 3090 KPG.Skill Trident Royal Z 32gb 3600EVGA SuperNova 1000w
3astardo
2020/11/03 02:43:02
Hi , When will EU get the PerFE 12 cable , I have Supernova 1000w G3
Almighty1337
2020/11/03 06:19:53
just need custom length now :)
dmisiur
2020/11/27 11:01:50
Getting these for my next build.
reeper167
2020/12/01 09:41:26
More of this! Keep it up!
osw2787
2020/12/04 14:48:42
Hello, I purchased a 120-G2-1000-XR back in 2015 and was planning to use it for a rebuild I'm doing though over the years I've lost the original cables that came with it. I was trying to figure out which of the cable sets would get me up and running here and I was having trouble confirming which of the following would be compatible with my PSU. 100-G2-13RR-B9 or 101-CK-0850-B9 Does the latter come with everything listed in the overview x2? If only the first one is compatible with my PSU that is fine too, I just wasn't 100% sure off the bat if that set is compatible with my PSU. Thank you! Shinji (edited since the links got removed)
2020/12/04 15:05:06
osw2787 Hello, I purchased a 120-G2-1000-XR back in 2015 and was planning to use it for a rebuild I'm doing though over the years I've lost the original cables that came with it. I was trying to figure out which of the cable sets would get me up and running here and I was having trouble confirming which of the following would be compatible with my PSU. 100-G2-13RR-B9 or 101-CK-0850-B9 Does the latter come with everything listed in the overview x2? If only the first one is compatible with my PSU that is fine too, I just wasn't 100% sure off the bat if that set is compatible with my PSU. Thank you! Shinji (edited since the links got removed)
Both look to be compatible. If you want to be 100% sure contact evga support and ask them too.
jayrwar
2020/12/14 19:13:28
ctn2mb
2020/12/16 15:22:33
eskimoe
2020/12/21 00:12:18
Any idea when we'll get restock on the EU store? Would like some sleeved cables for my 850 P2..
Initializing
2021/01/12 00:30:25
I just received the B3/B5/G2/G3/G5/GP/PQ/P2/T2 Black Power Supply Cable Set (Individually Sleeved) - Version 2 that bought from EVGA webstore, and the 24pin cable does not work with my 1000 supernova G2 power supply. When I try to turn on my pc, sometimes the LED on my cpu aio will flash once, the led on my MB keeps on as normal, and nothing else happens. Continue tapping the power button on my case does nothing. Only turn off the power supply with the switch on it will reset it. I have the following question: 1.the cable is relatively "poorly" packaged with a plastic bag, with only a sticker with part number on it. As all the tech support on EVGA website seems to require the registration of the product, how should I register this product? How should I get tech support and customer service for this product? 2.According to the information provided on the product page on your website, these cables should be compatible with G2 series power supply, including my 1000 supernova G2, while the 24pin cable does not work for me. Is that a product failure, or the cable is indeed not compatible with 1000 supernova G2 power supply but nothing is mentioned on the product page?? Thank you.
tskrzynecki
2021/01/24 15:51:37
I hope these are still in stock when I can finally buy my 3080
tskrzynecki
2021/01/30 04:15:27
Are there more than just the red and/or black cables still?
rabcora
2021/02/17 02:10:52
Hello, I would like to buy this kit (BA/B3/B5/G2/G3/G5/GP/GM/P2/PQ/T2 Black Power Supply Cable Set (Sleeved) P / N: 101-CK-0850-B9) for my EVGA SuperNOVA 850 G3, 80 Plus Gold 850W, but the US site does not ship to Italy. Someone show me a European link where to buy it. Thank you
rabcora
2021/02/17 02:13:26
Hello, I would like to buy this kit (BA / B3 / B5 / G2 / G3 / G5 / GP / GM / P2 / PQ / T2 Black Power Supply Cable Set (Sleeved) P / N: 101-CK-0850-B9) for my EVGA SuperNOVA 850 G3, 80 Plus Gold 850W, but the US site does not ship to Italy. Someone show me a European link where to buy it. Thank you
DCRX2020
2021/02/23 17:23:18
These cables should come with 3 vga cables to accompany the new cards. It's ridiculous that you'd have to buy another set just for one cable, and I think it's kind of robbery to sell these with only two vga cables.
damadama
2021/04/27 09:24:27
zuberch
2021/04/28 16:12:37
are they work with sfx 550?
sehla343
2021/04/28 16:42:26
looking forward to a change in color scheme on my cable schemes
Fangragon
2021/05/01 19:53:47
Look sweet, doesn't work on the G5+, well that sucks
Slippy103
2021/05/28 15:54:20
Do they come with cable combs?
Dwakey
2021/06/01 07:06:25
jdobson75
2021/06/01 09:30:02
This is nice, have wanted to get sleeved cables - but not from CableMod - would rather stick with the manufacturer's own.
Boywonder3737
2021/06/01 10:16:36
any chance evga will make any rgb sleeved cables?
anavik2
2021/06/02 11:24:46
Oooh I'm going to hit this up later. Gotta get rid of my red VGA cables and switch them out for black.
Hluciano55
2021/06/04 11:06:20
Wow these look good ! was debating on getting some from MOD-ONE cables but maybe i should stay in the EVGA family :)
jpender14
2021/06/05 16:06:50
anavik2 Oooh I'm going to hit this up later. Gotta get rid of my red VGA cables and switch them out for black.
Would those cables work with any other modular PSU?
ein385
2021/06/05 23:49:02
Hopefully they will get a restock of the white ones in by the time I find a GPU.
Meatus
2021/06/29 00:56:39
