sffsks11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2018/02/25 08:21:57
I making my own PSU cable's to all my components, I noticed some pins on the 18+10 to 24 pin have double wires. i noticed some pins have 2 wires on the 24 pin. is it safe to crimp 2 wires on a ATX pin ?
Wegason
2018/03/09 05:31:02
Vlada011 I think EVGA should add one more color for new generation of PSU T2 and next models. Grey. But not simple. Some cool variant. Example as Titanium Grey or Platinum Grey from MDPC-X or something between them. MDPC-X are cool colors and cool look but they are 5mm and should be 2-3mm and it would be far better to some manufacturer produce of them, I don't like how they move over wire and look unstable. I like this idea, a really popping titanium grey would go well with some of the graphics card colours that EVGA make.
EVGA_Lee
Moderator
- Ribbons : 14
2018/03/09 10:12:46
For what it's worth, guys, we're working on making sure that all new modular/semi-modular power supplies in the future will share the same pinouts, so if you end up purchasing one of the individually sleeved cables sets, specifically the ones listed with multiple PSU series, you should be able to use them on future EVGA power supplies.
- Ribbons : 115
2018/03/09 22:40:18
EVGATech_LeeM For what it's worth, guys, we're working on making sure that all new modular/semi-modular power supplies in the future will share the same pinouts, so if you end up purchasing one of the individually sleeved cables sets, specifically the ones listed with multiple PSU series, you should be able to use them on future EVGA power supplies.
That will help a lot.
EVGA_Lee
Moderator
- Ribbons : 14
2018/04/05 18:42:20
Added the new PQ power supplies to the list. Please note that you will still be purchasing the 24pin cable, and we cannot remove this from the cable kit. However, the rest of the kit will work with PQ power supplies.
tonycooper
2018/04/16 22:45:35
Hello to everybody.. Can you tell me where i can find plugs and tools for making my own cables? I need some specific length cables and i need to be the highest quality available.. What brand is the OEM Connectors in EVGA 1600T2 ? P.S : I would like to thank EVGA Europe for excellent service regarding my RMA.
Vlada011
- Ribbons : 11
2018/05/11 06:38:39
I saw some picture on EVGA site and I like Sleeve cables installed on that way. Not every wire to be in line and hold with plastic peaces, some people like I respect that but I like on this way... I think when some brand will build all PSU cables in rubber as you see power cord. Off course need to be thicker but that will be revolution. Imagine such improvement for cable management, durability, installation. And 24pin with cover for wires like EVGA 1200 SR2 PSU.
EVGA_JacobF
- Ribbons : 26
2018/05/14 11:22:36
Sleeved cables are 50% off this week, while they last :)
Vlada011
- Ribbons : 11
2018/09/02 14:27:12
EVGA_Lee
Moderator
- Ribbons : 14
2018/09/04 09:21:55
Vlada011 I see now EVGA have 2 different Black Sleeve Set, other is Version 2. https://www.evga.com/products/product.aspx?pn=100-NK-1601-B9 https://www.evga.com/products/product.aspx?pn=100-CK-1300-B9 What's difference between them? Size, different cables in pack, what else? No more 8+6 pin, only separate 8pin and 6 pin.
Hi Vlada, The Version 2 were sets that we originally created for a joint product with a third-party, which was ultimately cancelled. There are some obvious differences between the two cable sets, but the Version 2 may be something that customers using a smaller system or carefully designed system might use, given the different cable lengths. There is nothing electrically different between the cable sets, but you should carefully check the measurements before buying them, as noted in the Overview.
Vlada011
- Ribbons : 11
2018/09/04 10:54:22
EVGATech_LeeM
Thank you on answer. I'm very satisfied with my original kit.
Nutts
2018/09/07 20:19:54
I want to do my own cables Reused from my supply. But have not found the right para cord / prices any one have any idea's ? To where I can go to get supply's that do not cost so much?
Asus x399 2950X Thread Ripper 128Gb DDR4 3000Mhz Asus 2070 Super
Lutfij
2018/10/11 12:11:27
Hi there! I'm a long time user of EVGA products but this is the first time I've decided to post and ask :) I was wondering, the SFX range of GM PSU's, would they accept the individually sleeved cable sets? I will be investing in an SFX for my Compact Splash projects for which I will need the shortest cables possible.
post edited by Lutfij - 2018/10/11 12:25:59
EVGA_Lee
Moderator
- Ribbons : 14
2018/10/11 12:24:32
Lutfij Hi there!
I'm a long time user of EVGA products but this is the first time I've decided to post and ask :) I was wondering, the SFX range of GM PSU's, would they accept the individually sleeved cable sets? I will be investing in an SFX for my Compact SPlash projects for which I will need the shortest cables possible.
Hi Lutfij, The GM power supplies do, in fact, work with most of the Individually Sleeved Cable sets, and have been added to both the name and compatibility list for the cable sets.
Lutfij
2018/10/11 12:32:20
Hey EVGATech_LeeM, Thank you for the prompt response ;) When you mention, most, which ones can I look forward to when bundling/making a purchase with the SFX PSU? Asking just in case. I've looked through the compatibility tab for the SFX PSU's when viewing the shopping section but I guess being double/triple sure can't hurt.
EVGA_Lee
Moderator
- Ribbons : 14
2018/10/11 13:42:27
Lutfij Hey EVGATech_LeeM, Thank you for the prompt response ;) When you mention, most, which ones can I look forward to when bundling/making a purchase with the SFX PSU? Asking just in case. I've looked through the compatibility tab for the SFX PSU's when viewing the shopping section but I guess being double/triple sure can't hurt.
I say "most", because we still sell some cable sets for GS/PS and G1 (not GP, or G1+) power supplies, which are not compatible. If you look at the name of any of the cable sets, any compatible series of power supplies are listed in the name. Example: EVGA G2/G3/ GM/GP/PQ/P2/T2 Power Supplies.
Lutfij
2018/10/11 14:56:43
Noted and following advice. Thank you for the prompt response, as always!
mron0903
2018/10/17 14:30:44
Is there a cable set that is compatible with a B3 650 psu? Thanks!
2018/10/17 14:37:04
transdogmifier
- Ribbons : 17
2018/12/12 08:51:22
I don't mind the look of the cables that come with the unit....but I do mind the lack of length...sometimes I can't easily reach a spot in the case because the cable is about 2 inches too short.....I *CAN* make it, but it's stretched and extremely tight.....if I had 2 or 3 more inches on the cable it would be perfect. *shrug* maybe it's just me, but I would like longer cable lengths available to purchase ......
2018/12/12 11:01:14
transdogmifier I don't mind the look of the cables that come with the unit....but I do mind the lack of length...sometimes I can't easily reach a spot in the case because the cable is about 2 inches too short.....I *CAN* make it, but it's stretched and extremely tight.....if I had 2 or 3 more inches on the cable it would be perfect. *shrug* maybe it's just me, but I would like longer cable lengths available to purchase ......
Longer CPU power cords - would be nice, for those of use who prefer a Full Tower Even as an option / upgrade
rlb9682
- Ribbons : 11
2018/12/12 13:38:27
I love how long they are already, but yeah, I've got a full tower and there's maybe a 1/2" spare length so a little longer even as a separate option would be really nice.
Affiliate Code: PD1HHD50JK
Dingus42
2018/12/13 21:21:06
What's the story on these and the lack of in-line capacitors? Personally, I'd like to make my own set of custom cables, but the capacitor issue has me pausing.
Emris
Re: Individually Sleeved Cables for EVGA G2/G3/GM/GP/PQ/P2/T2 Power Supplies
2019/01/02 08:46:13
Hey all, I have a 850 G2 that I purchased about 3 years ago, but I seem to have misplaced all of my extra cables that came with my PSU. I am just needing one 8 to 6+2 pin VGA cable, but the compatible cable set is $90 right now and I'd really prefer to not pay that much when I only need one cable out of the set. Does anyone know of an alternative solution? Is there a way for me to buy a single cable? Thanks in advance! My PSU: Compatible Cable Set:
2019/01/02 12:04:59
Emris Hey all, I have a 850 G2 that I purchased about 3 years ago, but I seem to have misplaced all of my extra cables that came with my PSU. I am just needing one 8 to 6+2 pin VGA cable, but the compatible cable set is $90 right now and I'd really prefer to not pay that much when I only need one cable out of the set. Does anyone know of an alternative solution? Is there a way for me to buy a single cable? Thanks in advance! My PSU: Compatible Cable Set:
Contact evga support. https://www.evga.com/about/contactus/
gamernut78
2019/01/03 03:50:07
Do you have any sleeves that are UV reactive also how can I find a extension custom sleeve that is compatiable with EVGA 850 BQ series? I don't want to risk getting the wrong custom ones from another company. Can anyone recommend me a safe place to order one that fits the specific PSU I own?
Please help me earn some bucks to save money in the future as a team player and gamer! My Rewards Program Code: 6JD2JTSGVP
merrick97
2019/02/11 09:39:53
2019/02/11 12:24:57
529th
2019/11/06 07:16:45
Hi there. Old thread here, sorry to resurrect it, but I need a longer 24-pin ATX cable for my EVGA Supernova 1000w T2, and possibly longer 8-pin ESP CPU cables. I'm using an old Corsair 800D full tower with the PSU on the bottom I went through the FAQ and came across the product page again and I'm just not sure which are the best, and best quality for my PSU. Link: https://www.evga.com/products/productlist.aspx?type=10&family=Power+Supplies&chipset=Power+Supply+Cable+Set+(Individually+Sleeved) The 24pin is 580mm, and I think I would need close to 700mm for the 24-pin. I'd prefer black. Which one on the product page is best suited for my 1k watt T2? Thanks
2019/11/06 18:41:11
529th Hi there. Old thread here, sorry to resurrect it, but I need a longer 24-pin ATX cable for my EVGA Supernova 1000w T2, and possibly longer 8-pin ESP CPU cables. I'm using an old Corsair 800D full tower with the PSU on the bottom I went through the FAQ and came across the product page again and I'm just not sure which are the best, and best quality for my PSU. Link: https://www.evga.com/products/productlist.aspx?type=10&family=Power+Supplies&chipset=Power+Supply+Cable+Set+(Individually+Sleeved) The 24pin is 580mm, and I think I would need close to 700mm for the 24-pin. I'd prefer black. Which one on the product page is best suited for my 1k watt T2? Thanks
Sounds like you need to buy some custom cables from cablemod.
