nameste
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2014/06/01 18:24:05
i want to know: are these sleeved cables enough for 3x amd 290 to use with a 1300g2?Or for only 2 vga cards?
Mark of Omaha
2014/06/11 19:42:21
I will be ordering a SuperNOVA 1000 G2 or P2 power supply this weekend (probably the P2). These individually sleeved cables look great and I may order a set later. However, I have two questions: 1: How long are these cables? I can't find any information regarding their length vs. the stock power supply cables. Maybe I'm looking in the wrong place? 2: These cables lack the capacitors that are present on the stock cables. How will this affect the performance of the power supply?
ManBearPig
- Ribbons : 20
2014/06/26 17:21:50
Will these cables be compatible with the new 1600 G2?
EVGA_JacobF
- Ribbons : 26
2014/07/21 11:40:07
vsg28
- Ribbons : 17
2014/07/21 13:14:55
I should have seen this earlier! If anyone has a question or specific request about these with EVGA PSUs, let me know. I got a kit that I did an overview on here: http://forums.evga.com/FindPost/2190030
FR3D1
2014/08/17 00:53:46
looks real good are they also UV reactive?
muathusanjose
2014/08/23 00:42:13
how long are they measure ? will they long enough for big full tower case ?
Dell UP2715K 5K Monitor Asus Strix Z270E ~ i7-7700K @ 4.7 GHz 1.264v G.SKILL TridentZ RGB 16GB DDR4 3000 Samsung 960 Pro M.2 512GB EVGA SuperNOVA 850 G3 PSU EVGA GTX 1080 Ti SC2
Vlada011
- Ribbons : 11
2014/08/23 06:10:41
post edited by Vlada011 - 2014/08/23 06:20:59
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2014/09/13 02:29:04
I wanted to get a new PSU, since my Seasonic doesn't like the x79.. Low and Behold, Newegg is running the 1300 G2 for $170.. DEAL! Now, I need to figure out if I want to get the individually sleeved cables. Are the 8 pin PCI split from the PSU itself and not split in the middle somewhere. I just want to make sure it isn't this sort of connector: Some of the NewEgg pictures are confusing. and I don't like the picture cables at all.
VVhiplash
2014/11/01 10:57:56
I'm doing a black and blue theme for my new x99 build, and am looking at the blue cables. They look slightly PURPLE though, can anyone confirm whether or not it has a purplish hue to it? Are there other pictures somewhere? Thanks for the help!
ll Steiger-Dynamics Maven ll Intel i7-5930k 4.2Ghz ll ASRock X99 Extreme6/AC ll Liqmax II 240 ll GeiL Super-Luce 32gb 2666mhz ll (x2)EVGA GTX 980 SC ll Samsung XP941 500gb and 850 Pro 1TB ll EVGA PS 1000W Platinum ll
ritzusan
2014/11/08 15:16:38
Hello, The white cables are out of stock in EU website. How long it will take to have them back in the "online shop"? Thanks.
mistermister
- Ribbons : 13
2014/12/05 09:32:33
Wish I could pick and choose which cables to get instead of a $80+ package. Perhaps in the future?
AMD 3700x / X-570 Aorus Ultra / RTX-3090 FTW3
LovEVGA
2014/12/08 06:27:13
vieuxchnock
2015/01/01 09:32:34
I'm loking at those wire kit for my 1300 G2. It looks like the sleeved wire do not have the capacitor on them. They are not more important than that?
Asus P9X79-E WSi7-4820 WatercooledCrossFire Radeon R9 290 1175/1500 WC16Go DDR3 2133 G.Skill Ripjaws Z cas 9 WC2 X Samsung 840 Pro 256 Gb Raid 0 OSOCZ Revodrive 230 Gb PCIeX4 GamesWD 1 TB Storage3 X Asus VG 248QE 144Hz EyefinityEVGA Supernova 1300 G2Win 8.1 ProCase Corsair 450D
Vlada011
- Ribbons : 11
2015/01/02 02:13:54
I don't know for capacitors, many power supplies don't have them. They help in delivering clean power to components in some percent. I think for 2 weeks and my Black should arrive. Sleeve cables and zip ties are necessary part of all nice build RIGS.
DarkIdeals
2015/01/10 21:40:58
Where the hell are you guys buying these from? I'm looking everywhere and they're out of stock! The listing on the evga website just has an "auto notify when available" on every single cable set and it's out of stock at amazon, frozencpu, newegg etc.. so i don't know what to do. My only other option is to buy a ridiculously overpriced Corsair AX1200i for nearly $300 + spend $100 on cables? -____-
- Ribbons : 115
2015/01/10 21:56:54
DarkIdeals
2015/01/11 08:08:43
XrayMan Currently in stock at Newegg: http://www.newegg.com/Product/Product.aspx?Item=12-527-003
Cool, thanks :) Do you think that a Supernova 1000 G2 would be enough to run an I7 4930K and 3 way GTX970's in a water loop? I saw one on sale for pretty cheap ($139 or best offer, gonna try $125 auction ends in a couple hours though) but i don't wanna end up kicking myself for not going P2 1200 or G2 1300 since i'm gonna be doing 3 way SLI eventually.
Vlada011
- Ribbons : 11
2015/01/11 12:28:58
1000 G2 will work with GTX970 3-Way SLI. 3-way GTX970 is I think similar as GTX780Ti SLI eventually. But if you change in future on some stronger graphics with higher power consumption and want to overclock together with Processor, than SLI will be better.
DarkIdeals
2015/01/11 13:06:25
Vlada011 1000 G2 will work with GTX970 3-Way SLI. 3-way GTX970 is I think similar as GTX780Ti SLI eventually. But if you change in future on some stronger graphics with higher power consumption and want to overclock together with Processor, than SLI will be better.
Yeah that was my thought, that if 1000 was enough, i might as well go 1300 so i won't have to buy a new psu in 2 years when i'm going for SLI GTX980 ti's or something. The thing that is worrying me right now though is what order to buy my parts in, i bought a rampage IV black edition mobo and i'm gonna get an i7 4820k cpu and planning on putting it in a corsair 900d case using a corsair h100i for temporary cooling till i can afford a full water loop. but i can only afford to get either the RAM or the PSU, i currently have some ugly as hell a-data "pcb style" 8gb ram and an XFX TS 550 watt 80+ bronze power supply. So i'm not sure whether i should stick with the ugly RAM and get an EVGA supernova or corsair AX1200i psu first getting the ram later in a few months when i can afford it, or buy the 16gb corsair ram i want and stick with the 550 watt psu until i can afford a new psu. Not sure if a 550w would be enough to power a gtx970, i7 4820k, the rampage black motherboard, and a total of 10 fans properly. It runs my I5 3570K, GTX970, H61 motherboard, 2 fans etc.. just fine but i'm not sure if it'll be enough for all that new stuff.
post edited by DarkIdeals - 2015/01/11 13:09:14
rsabatino
- Ribbons : 6
2015/01/13 15:51:37
Operation System Microsoft Windows 11 Pro Processor AMD Ryzen 9 5950X 16-Core Processor Memory 24.2 GB Free (31.9 GB Total) Graphics Card NVIDIA GeForce RTX 3070 Ti (8.0 GB) Monitor HP 32 Display (1920 x 1080 @ 60 Hz) Disk Storage 5240.5 GB Free of 6542.2 GB Audio NVIDIA High Definition Audio Motherboard ASUSTeK COMPUTER INC. (ROG CROSSHAIR VIII HERO (WI-FI)) Mouse Razer BlackWidow V3 Tenkeyless Keyboard Razer Viper
Heini2
2015/01/19 06:05:35
Anyone cars to make a guess if these will work with the new "220-PS-1000-V1" supplies?
Z170 Sabertooth Mk1 / i7-6700K + NH-D15 / Trident Z (2x16GB)@3000 / 2080Ti XC Ultra / Essence STX II / 950 Pro 512GB / G3 1000W / MG279Q / HAF XB EVO / Win10 X64 Pro
Vlada011
- Ribbons : 11
2015/01/19 06:14:28
Heini2 Anyone cars to make a guess if these will work with the new "220-PS-1000-V1" supplies?
I think not, that's probably Seasonic XP2 Platinum inside. But maybe EVGA launch new cable set for them or leave exclusive for 1000 G2/P2/T2.
Arblarg
2015/01/20 18:34:00
Is there ever any chance EVGA would sell a PSU with the braided cables instead of the standard cables that come with the PSU? I would expect it to still cost more than the PSU with the stock cables, but obviously less than the PSU with stock cables + buying the braided cables alone. Would certainly be very interested in this becoming an option. If not I guess buying them separate is ok too.
Vlada011
- Ribbons : 11
2015/01/21 00:11:29
Arblarg Is there ever any chance EVGA would sell a PSU with the braided cables instead of the standard cables that come with the PSU? I would expect it to still cost more than the PSU with the stock cables, but obviously less than the PSU with stock cables + buying the braided cables alone. Would certainly be very interested in this becoming an option. If not I guess buying them separate is ok too.
PSU price would be much bigger than and more than competition and some people don't like that. It would be bad to someone choose other model only because cables, and what color to choose in every package. How many PSU with red, how many black, how many blue, maybe most of people choose black, what than to do with PSU + blue cables... It's to complicate. Nice when PSU arrive you choose cables in color you want and that's it.
Grey_Beard
- Ribbons : 10
2015/01/26 04:35:19
Will these cables fit a 1600 T2?
Vlada011
- Ribbons : 11
2015/01/26 08:52:49
Yes 1600 T2 is now on list of supported models for Sleeved PSU Cable Set. And 1600 G2/P2 Additional PSU Set is compatible with T2 if someone use 3-4 graphics. New List of supported models with 1600 T2 if someone need.
post edited by Vlada011 - 2015/01/26 09:00:38
Grey_Beard
- Ribbons : 10
2015/01/26 10:52:44
Vlada011 Yes 1600 T2 is now on list of supported models for Sleeved PSU Cable Set. And 1600 G2/P2 Additional PSU Set is compatible with T2 if someone use 3-4 graphics. New List of supported models with 1600 T2 if someone need.
I saw that right after posting this. Already ordered them and the additional ones. Should go nicely with my rig. The only issue on the original cable is that there are not enough four-pin or MOLEX cables, but understand the movement to the SATA type connectors. Having an additional one with the expanded package is nice, as there is some power loss when you need to split those that much to get everything powered.
Grey_Beard
- Ribbons : 10
2015/01/31 18:33:28
These cables are fantastic. They have really cleaned up the look of my rig. Good job, EVGA, good job!
soybean
2015/02/06 20:12:37
would these work with the evga 220-gs-0850-v1 850 psu or should i keep looking around?
