Individually Sleeved Cables for EVGA G5/G2/G3/GM/GP/PQ/P2/T2 Power Supplies
Page: << < ..678910.. > >> Showing page 6 of 12
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/01/25 16:31:28 (permalink)
dark4181
Any way to get custom cables that will route easily to the hard drive mounts in my Define S?
We can do custom cable kits - email us to community@cablemod.com
Steveohh
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/01/26 10:40:56 (permalink)
Any time table on when the White G2 Cables will be back in stock? Been checking for the last few weeks now.
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/01/26 14:09:10 (permalink)
will be back in stock by the end of next week - sorry for the shortage.
Methodical2
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/03 10:59:13 (permalink)
Vlada011
It's more like nylon.
Are these harder to work with than the paracord version?  Are there any advantages the nylon versions have over the paracords?
Thanks
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
BlackE
Case:  Caselab Magnum STH10
MB:  Asus X670E Hero
CPU:  Ryzen 9 7950x (EK-Quantum Vector²)
GPU:  Asus 4090 TUF OC (EK-Quantum Vector²)
Memory:  G.Skill Trident Z5 Neo DDR5 (6000 @64gb)
Storage:  WD M.2 NVMe 2TB (OS), 2x4TB (Photography), 1TB (Games)
Fan Controllers: Aquacomputer Aquaero 6 XT & Octo
PSU:  EVGA 1200 P2
Monitor:  LG 48" UltraGear OLED 4k
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/03 16:32:34 (permalink)
Methodical2
Vlada011
Thanks
the advantage of our Paracord sleeve is that it is much more flexible and makes your life easier when it comes to cable management and touring.
Methodical2
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/03 17:00:21 (permalink)
CableMod
Methodical2
Vlada011
Thanks
Thanks for response.
BlackE
MB:  Asus X670E Hero
PSU:  EVGA 1200 P2
Steveohh
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/05 11:19:13 (permalink)
CableMod
 It's the end of next week.
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/05 12:56:40 (permalink)
should be in a couple of hours.
OGM3X
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/06 14:10:00 (permalink)
Just ordered and installed the red cables . Gotta love amazon same day shipping
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/06 16:36:57 (permalink)
oG kill3r
Thanks for your support! :)
Steveohh
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/11 13:36:21 (permalink)
CableMod
144 hours later still not in stock.
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/11 15:09:14 (permalink)
guess you got unlucky and they are all gone already - email us to community@cablemod.com and we will find a solution for you.
Methodical2
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/13 17:14:44 (permalink)
Can anyone post a photo of the MB cable showing the pin layout of the motherboard connector side?  I'd appreciate it.
Thanks
BlackE
MB:  Asus X670E Hero
PSU:  EVGA 1200 P2
CableMod
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/13 17:17:05 (permalink)
if you are referring to that our 24PIN cable has a different PIN OUT than the one that comes with the PSU - the reason for this is that our cable kits are based on the official sleeved cable kits of EVGA that have the exact PIN OUT like ours which is different to the stock 24PIN cable that comes with the PSU.
F34R
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/16 04:03:12 (permalink)
Does using CableMod cables void warranty of the PSU?
  • Ribbons : 115
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/16 19:39:37 (permalink)
F34R
If you ruin the unit with those cables, then yes. No Warranty.
            My Affiliate Code: 8WEQVXMCJL
 &nbsp
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/16 22:59:37 (permalink)
Warranty only with EVGA Power Supply Cables, and they are more durable, and look finer.
My sharp eye notice from high resolution pictures. Cable Mod cables are more sensitive and on dust.
But I agree after EVGA Sleeve second best are Cable Mod.
They saved guys with Seasonic XP3 series.
post edited by Vlada011 - 2016/02/16 23:13:21
http://www.evga.com
http://www.intel.com
http://www.nvidia.com
https://watercool.de
http://www.lian-li.com
F34R
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/17 00:18:37 (permalink)
Okay so no warranty void with EVGA individually sleeved cables?
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/17 00:37:54 (permalink)
F34R
Yea, EVGA never sell something if destroy warranty on their hardware.
Same thing is with EVGA Hydro Copper blocks, EVGA Hybrid Coolers, EVGA ACX 2.0 Coolers and EVGA Power Supply cables.
All of them customers could order and install on hardware and warranty will stay intact.
http://www.evga.com
truejunglist
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/22 21:11:50 (permalink)
Any estimate on a restock for the EVGA G2 white individually sleeved cable set?
mrkwhlr2
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/24 04:43:07 (permalink)
I got the CM-EV2-FKIT-KW-R kit from cable mod the other day, they were in stock. I was going to wait until EVGA had theirs in stock and was on the auto notify but my pc was all tore down waiting on new motherboard so it was the right time to swap out. Got the set from Performance PC.
Corsair Obsidian 800D |  EVGA Z490 Dark | EVGA 2080 ti  Hydro Copper | i9 10900K w/EK Supreme HF H20 block | 2x500gb Samsung 980 PRO M.2 Gen 4.0 | 2x8gb G.Skill Trident Z Royal DDR4 4000 | EVGA SuperNOVA 850 T2  | r.i.p JH......
mrkwhlr2
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/02/24 04:43:53 (permalink)
well, crap...just went there to get you a link, they are out of stock as well. Must be a real popular item.
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/03/01 01:22:23 (permalink)
This Topic should be Edit and add compatibility with T2 models same as GS PS Individual Sleeve Cables.
I can bet 50% of owners don't know for available Sleeve Set for them for 850 GS - 1050 GS - 1000 PS in Black, Red and White Color.
Even for 550 GS and 650 GS.
http://www.evga.com
Jinxedx84
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/03/20 00:00:13 (permalink)
Im having a really tough time find a set for my 1000w PS. Cablemod isnt compatible. And the ones evga offer and either black out white.    Help?
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/03/20 05:32:27 (permalink)
EVGA white set look very nice, maybe best of all colors, but I like black and they are standard and always will fit with any configuration.
I didn't want other colors and because black was not available in that moment in Europe I wait and bought few weeks later.
Are you satisfied with your 1000 PS?
I recommend to everyone who want smaller PC case and mATX motherboard to buy 1000 PS.
Somehow I would feel bad now with lower PSU than 1000W even with single card.
http://www.evga.com
Separatist
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/03/28 10:28:39 (permalink)
Hi Guys,
Do you have any cables in stock which are compatible with the G series of your PSUs.
I have the 1000G PSU in my system.
Thanks in advance!
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/04/01 03:22:09 (permalink)
Separatist
Hi Guys,
Thanks in advance!
Can you tell us exactly model. If you have 1000 GS or 1000 G2 than Yes, if you have 1000 G1 than No.
I think EVGA should think to offer one set of short sleeve cables for small PC or set of short ribbon cables compatible with G2/P2/T2 models.
Or maybe even to build one 700/750W PSU in SFX format with ribbon cables or very short ATX format.
At the moment only Silverstone produce such PSU and it's 90% choice of people who build small RIGs where they need short ATX or SFX PSU.
They only offer small, short but powerfull efficient PSU models, 650/750W Platinum with 100% ribbon cables and option to people buy short ribbon set.
At the moment they have no competitor and platform OEM, Brand of some capacitors on their best PSU is not what most enthusiasts like to see but they have no other choice sometimes.
post edited by Vlada011 - 2016/04/01 03:24:43
http://www.evga.com
Separatist
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/04/01 03:47:39 (permalink)
Its cool, I have been through EVGA support with this query, basically they only have the G1 model aka 1000G supanova braided cables in red and black.
Plus I live in the UK and the European website isn't stocked as well as it is in the US, Also, interestingly, I was told I couldn't import from the US through the Euro site, which I found quite strange.
Anyhow, you're quite correct, they don't do sleeved cables for my model only the GS G2 etc.
I guess I'll have to just do it cable by cable and avoid those bespoke connections like the mobo power connector, its not that ugly, and I'm not a pro PC builder so it wont piss me off too much, I just want a tidy rig really, but the consumer market is a bit of mine field it seems.
I guess my first port of call will be to find a braided VGA cable for my GPU as its the most visible, its an 8 pin to x2 6 pin and tips/pointers would be gratefully received.
Thanks for getting back to me!
post edited by Separatist - 2016/04/01 03:54:50
Vlada011
  • Ribbons : 11
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/04/01 06:22:30 (permalink)
I think Bitfenix make some nice extensions for 8pin CPU, 24pin, 8pin PCI-E and 6pin PCI-E.
You should check on their site.
http://www.evga.com
druger81
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies 2016/04/12 08:34:28 (permalink)
Will these work with the 650 g1? I just got it and was hoping to get some blue cables.
