MasterBuilder64
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2019/12/30 05:05:06
Cables do indeed look very nice and look like the E-Series replacement kit from Cablemod costing 99 Euros. Can anyone quote the price and delivery times for the EVGA offering? Where in Europe are they shipped from? Besides talking about the looks though I think there is a more serious consideration worth mentioning which is with new processors and motherboards the build process has changed. More CPU Power, more heat, more sophisticated water cooling solutions often mean bulky motherboard heat sinks and coolers occupy spaces where cables could be run. More prescriptive (and better) cable routing built into cases like the NZXT 710i I am using makes for easier cable routing but choices are limited as is the space behind the motherboard, I mean the ATX cable on my brilliant Supernova T2 850 Titanium is not only difficult to flex its 20mm thick. Why do I mention this? Well because imho the days of the old inflexible, difficult to manage and flex power supply cables are numbered they just are not fit for purpose in combination with other components as part of a modern PC build. Flexible, sleeveless braided cables are the way to go and should be provided as standard not as an expensive addon that costs almost as much as the power supply itself in some instances. This is not a specific whinge about EVGA I think all power supply manufacturers need to start thinking this way. I have attached some images which show, what turned out to be the infeasible cable twisting of the ATX and EPS cables needed to complete my build which is currently on hold until I can get a replacement cable kit like those being discussed here.
post edited by MasterBuilder64 - 2019/12/30 05:12:59
mellowfluff
2020/03/24 23:14:15
Any chance of G5 psu compatibility? I would love a cable kit of these for my 1000W G5.
Governator
2020/03/30 21:06:19
I like the idea of these but I frankly wouldn't need all of them except the 24 ATX, 8 EPS and a couple of SATA.
HEATWARE Mobo: Asus Z690 Maximus Extreme (BIOS 2103) | CPU: Intel Alder Lake i9-13900K (@6.2Ghz) w/EK-Quantum Velocity² D-RGB Nickel + Acetal | GPU: Evga 3080Ti FTW3 Ultra w/EKWB Quantum Vector | RAM: 64GB DDR5 (2x32GB) Kingston Fury Beast KF556C40BBK2-64 @XMP2 | SSD: 2x WD SN850 2TB NVMe (m.2_2, m.2_3) | Power Supply: EVGA SuperNOVA 1600 P2 | Cooling: Dual Loop 2x EK-Quantum Kinetic TBE 300 D5 PWM D-RGB - Plexi / HWL 420GTS/Corsair XR5 420 Rads | Case: Corsair 7000D Airflow | OS: Microsoft Windows 11 Pro 64 Bit | Monitor: ROG Strix XG438Q | KB: CORSAIR K100 RGB Optical-Mechanical | Sound: Onboard Realtek via SPDIF (Logitech Z625 THX)
SimonOcean
2020/05/07 14:11:05
Think 1: Caselabs Mercury S5 | Retired Think 2 rev B: Caselabs Magnum SMA8/A | MSI X570 Tomahawk | R7-5800X | G.Skill DDR4 3200 MHz 14-14-14-34 | MSI RTX 3090 Suprim | 2x Samsung 970 Evo 2TB | EVGA SuperNOVA P2 1200 | Dell UP2715K 5K monitor | Twin custom water-cooling loops with Hardware Labs GTX 560 and GTS 480 with D5 pumps and Aquaero 6 XT control
blkburban
2020/07/10 08:28:22
Quick question, All of the Stock cables for my 1600P2 have caps in them and the sleeved kits do not, what effect will this have on my MB and dual 2080 hydrocoppers? 24 pin = 3 caps vga = 1 cap (2 per video card) cpu = 1 (2 to M/B) if they are not needed why put them there on the stock ones? should I move the caps to the sleeved cables?
2020/07/10 11:46:46
Caps reduce voltage ripple.
blkburban
2020/07/10 11:53:58
Sajin Caps reduce voltage ripple.
Sajin, OK, but are the sleeved kits less susceptible to ripple due to cable gauge or manufacturing material, or is it just not necessary to have the caps?
2020/07/10 11:55:14
EVGA_Lee
Moderator
- Ribbons : 14
2020/07/10 14:03:15
blkburban
I think the better way to look at it is that the 1600P2 has excellently-low ripple when using cables without capacitors, but has even lower ripple when using cables with caps designed for a specific power supply. Power supplies at the quality level of the 1600P2 are really just fighting for bragging rights when it comes to the amount of ripple under stress tests that push power supplies far beyond their actual rated specs. The amount of ripple that can occur with either set of cables is far too low to be concerned about potential damage to components. Myself, I have a 1600 T2 using our individually sleeved cables, and it's been running that way for a very long time. I don't have any concerns over it, and I can push the system to easily surpass 1200W at the wall. Would any ripple be improved by going back to the stock cables? Sure, but that doesn't mean that the power supply is anywhere near a hazard because ripple may be slightly higher.
blkburban
2020/07/10 16:01:50
EVGATech_LeeM
blkburban
Lee\Sajin, Thank You for your quick response.
2020/07/10 16:53:52
davew277
2020/07/15 17:40:08
merrick97 DO these come with cable combs like this?
kostacurtas Is there any compatible comb set for the 750-850 G2/G3/P2/T2 Power Supply Cable Set? Do we know what is the width of the cables in this set?
I haven't received the sleeved cables for my G3 yet. But from what I gather while searching for comb options the mobo/atx power connector has wires with 2 different diameters making any currently available comb options flawed since the combs are either too tight and break on the bigger wires or they are too loose on the smaller wires. I don't understand why EVGA wouldn't offer a solution to this, but whatever. Since the cables were only $40, are a lot cheaper than the alternatives and I have more confidence in their reliability I went with the EVGA option. I've read reviews from people using other options that had problems ranging from crossed wires to spliced cables to smoke coming out of their case. I don't want to worry about potential issues with my power cables and possibly damaging any of my hardware. I also don't want to use extensions... I've decided to lace my cables since I have nothing but time right now. I can lace all of my cables for less than $5 worth of thread. Combs cost a lot more than that. If you're interested then Google "psu cable lacing" or "psu cable sewing" and watch the videos. I've seen at least 3 different videos on it. I personally think it looks better than combs as well. But it does take some time to do and the appearance will come down to how well you do it. I also read a detailed tutorial on another forum. I don't know if I'm allowed to link to other forums though.
gravedigger78
2020/09/21 07:48:53
On the all black sleeved cables designated version 2, can the CPU cables be split? I have a 8 pin and a 4 pin on my motherboard. Also what is the difference between V1 and V2 for the cable sets? Thanks in advance.
EVGA_Lee
Moderator
- Ribbons : 14
2020/09/21 16:56:40
gravedigger78 On the all black sleeved cables designated version 2, can the CPU cables be split? I have a 8 pin and a 4 pin on my motherboard. Also what is the difference between V1 and V2 for the cable sets? Thanks in advance.
By split, if you mean are they 4+4, I believe the answer is "no." They are straight 8pin to 8pin cables. V2 is really just a spare set of cables left over from a project we worked on with NVIDIA. Because they requested very specific cables and cable lengths for a specific build design, the V2 version is a bit of an odd bird. Please check the cable lengths carefully for each cable before you purchase them. V2 really means more of an alternate version, rather than an upgrade.
mistermister
- Ribbons : 13
2020/09/22 13:29:54
Can anyone please confirm the number of 8-pin PCIE cables which come in this set? The wording under specs leads me to believe there are eight (?) 8-pin cables but that seems a little excessive. I just want to make sure Id have enough to run a new 3080/3090 with 2 or 3 8-pin connections. Also is this available in black? I didn't see that option on the webstore. https://www.evga.com/prod...aspx?pn=100-G2-13RR-B9
AMD 3700x / X-570 Aorus Ultra / RTX-3090 FTW3
2020/09/22 13:31:09
mistermister Can anyone please confirm the number of 8-pin PCIE cables which come in this set? The wording under specs leads me to believe there are eight (?) 8-pin cables but that seems a little excessive. I just want to make sure Id have enough to run a new 3080/3090 with 2 or 3 8-pin connections. Also is this available in black? I didn't see that option on the webstore. https://www.evga.com/prod...aspx?pn=100-G2-13RR-B9
8x 8pin (6+2)
mistermister
- Ribbons : 13
2020/09/22 13:32:56
Sajin 8x 8pin (6+2)
Yes that's how I read it initially. Well then, it looks like I'd have quite a few extra cables! Not bad for the cost.
EVGA_Lee
Moderator
- Ribbons : 14
2020/09/22 13:43:19
6 Cables, 8 Connectors. 4 of the cables are single 6+2 PCIe, and the other 2 cables have 2x 6+2 PCIe. Which power supply do you have?
mistermister
- Ribbons : 13
2020/09/22 13:47:08
EVGATech_LeeM 6 Cables, 8 Connectors. 4 of the cables are single 6+2 PCIe, and the other 2 cables have 2x 6+2 PCIe. Which power supply do you have?
EVGA SuperNOVA 1300 G2 80 Plus Gold
EVGA_Lee
Moderator
- Ribbons : 14
2020/09/22 13:53:19
mistermister
- Ribbons : 13
2020/09/22 13:57:28
EVGA_Lee
Moderator
- Ribbons : 14
2020/09/22 14:20:14
No issues, as far as I'm concerned.
kcwiro
Re: Individually Sleeved Cables for EVGA G5/G2/G3/GM/GP/PQ/P2/T2 Power Supplies
2020/09/24 06:10:03
kcwiro
2020/09/24 06:12:12
i rememeber makign rounded cables out of conduit from the hw store =)
mishmashmush
2020/09/24 07:48:11
Cody1174
2020/09/26 07:06:49
Buying as soon as the store comes back up.
Ryzen 7 3700X - Asus TUF X570Plus- Gskill Flare X 16gb CL14 - MSI 5700XT Evoke OC
ElementalFunk
2020/09/26 09:43:13
I just got my Black/Orange set and they're amazing! Very high quality cables.
themlharris
2020/09/28 07:22:21
Sheriff Brian
2020/09/30 22:41:25
These are looking sick! Nice work!
NobleNomad10
2020/10/01 00:39:33
