calebwwk
zila1 Is there an actual video of someone taking that shroud off? I haven't seen one with an in depth look at how it is done. Are there special tools required such as mini Torx? I have an EVGA GTX 1070 FTW2 that I have been wanting to take the fan shroud off of but can't seem to figure out the right way to do it. Any tips guys? Edit: Never mind. I got it.
I need some help with removing the fan and fan shroud, can I remove them without removing the backplate? Also do I need a hexagon screwdriver aka allen key?
Re: I need some help with removing the fan and fan shroud
2019/10/27 08:46:31
I moved your post from inside of a over 1 yr old thread - to your own thread - this Is the best way for you to get Help What specific GPU part number do you have ? How to do things on the EVGA Forums Ultimate Self-Starter Thread For New Member
calebwwk
2019/10/28 05:00:18
Cool GTX I moved your post from inside of a over 1 yr old thread - to your own thread - this Is the best way for you to get Help What specific GPU part number do you have ? How to do things on the EVGA Forums
Hey, thanks for responding, it's 08G-P4-6573-KR.
2019/10/28 05:02:43
2019/10/28 05:05:34
Locking this thread as Duplicate thread... I did not see your other thread when I moved you Post to its own thread (this one) Lets try to keep this in 1 Thread - looks like this thread was First: Disassemble GTX 1070
