So it seems i got a bit unlucky with my hybrid kit, it has a constant buzz to it. from what i can tell, its the pump running at max speed. the system has been on 50+ hours and it hasnt changed also doesn't sound quite like trapped air. does anyone have experience with this, is there any other solution other than soldering a tacho wire onto the pump that for some reason is not there to begin with? thanks.
