Asking for info pertaining to the cooler itself, not the shroud or accompanying fans.
I have a 120mm GTX hybrid unit that I can install into the RTX card.
Additionally I also have the power adapter necessary to power the pump and fans.
Are there any physical change between the RTX and GTX 120mm AIO units? If yes, what are the changes?
Would there be factors that prevent installation? I plan to install the cooler with the stock spring-loaded screws.
Thanks in advance.
