Re: Hybrid cooler 70c regardless of fan rpms
2019/04/12 04:35:17
gb288602
I upgraded my card with the hybrid kit and I'm confused about the temps. It usually runs 65-70c which seemed a bit high. So I swapped the stock fan to a BQ Silent Wings 3 fan which also got about the same. So I added another SW3 as a push/pull exhaust out the back (installed above the card with tubes on bottom) and this even got about the same (65-70). I added a slot cooler blowing more air on the card without any change. I noticed if I crank the fans up or down the temperature stays pretty consistent. I've also tried increasing or decreasing the pump (it's loud at 100% power but silent at 50%) but temperature consistent regardless of pump speed. The card isn't downclocking either.
Any idea what's going on? I have a Corsair h115i pro as intake and the CPU stays pretty cool (under 45c).
To me it sounds like the heatsinks aren't making proper contact with the GPU can you give full specs and what software you're using to monitor the temps?
AMD Ryzen 7900x3d
Deepcool LT720
Gigabyte Aorus Elite AX X670 (Might change..don't like this board)
eVGA GeForce RTX 3090 FTW3 Ultra Gaming (Hybrid kit on it)
Asus ROG Swift PG43UQ 4k Monitor
eVGA 1600W Supernova T2 PSU
32GB Kingston 6000 DDR5 (2x16GB) Fury
Corsair MP600 Pro 2TB (Boot)
Corsair MP600 2TB (Games/Data)
Phanteks P500A Case
