Re: Hybrid Cooling Kit VRM Fan Not Running
2022/05/23 03:30:43
In Presision Fan 2 is the VRM fan on the Hybrid kit. By default the fan wont spin until the core hits 50c or so. You should be able to control this manually or create a fan curve. Make sure the wires are not touching the fan some of them can get in the way the when screwing the shroud down.
I9 10900k @ 5.1 / 32 GB DDR4 4133 16-16-16-36 / EVGA 3080 Ti XC3 w/Hybrid Kit
I7 6700K / 32 GB DDR4 / EVGA 1080 w/Hybrid Kit
I7 3930K @ 4.3 / DDR3 32 GB ram / EVGA GTX 780 x 2
I7 960 24GB GB Ram / GTX 570 / EVGA X58 SLI3
Q6700@3.0 8GB of Ram / EVGA 780i
