AnsweredHow many Comsume Ampere for EVGA Hybrid Kit Pump?
DesireZ
2019/10/23 09:58:39 (permalink)
im use 400-HY-5598-B1(Evga Hybrid kit).
i want connect pump power cable to Corsair Commander pro.
it is 1A per pwm channel.
400-HY-5598-B1 is how many Ampere ?
can i connect this cable?
tattude69
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/23 16:11:54 (permalink) ☼ Best Answerby DesireZ 2019/10/23 17:29:14
Honestly i would plug it into the graphics card and use it as it was designed.
DesireZ
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/23 17:29:52 (permalink)
okay but I want to know the exactly A or Wattage.
  • Ribbons : 135
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/23 17:39:35 (permalink)
DesireZ
It's a standard AIO pump from Asetek. Using it on a 1 amp header is perfectly fine.  Of course if you need an exact to the milliamp answer, email evga
https://www.evga.com/support/
post edited by HeavyHemi - 2019/10/23 17:41:57
DesireZ
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/23 17:58:59 (permalink)
When connected to a graphics card, does it function as a full rpm regardless of the speed of the cooler that is connected with it?
  • Ribbons : 135
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/23 20:25:41 (permalink)
DesireZ
It is designed to be run at a single speed. It runs at the same speed, 100% regardless of what the cooler fan is doing. I could not tell you if they have wired the PWM for the pump or if it will just run a single speed unless you use DC control.
I
  • Ribbons : 270
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/24 05:12:16 (permalink) ☄ Helpfulby DesireZ 2019/10/24 05:14:55
That's it. They have not wired PWM to the pump. The pump gets the +12v and ground, but does not get a PWM signal, so it runs at full speed. The only way to adjust its speed is to use DC control to lower the +12v down to a range between +7v and +12v.
  • Ribbons : 135
Re: How many Comsume Ampere for EVGA Hybrid Kit Pump? 2019/10/24 12:30:45 (permalink)
Correct. It is not wired for the pump power splitter for the AIO. However I am pretty sure the pump itself IS wired for PWM and you can use PWM control. It is not used on the GPU as it is wired for +12 only.
