warrior10
It seems these days with the Internet getting so much bigger with even more information about how to Mod Gpu's with better Air and Water cooling, it seems almost to be the Norm now. Next month i will be getting the EVGA Water block myself.
post edited by warrior10 - 2017/03/24 14:38:41
My new https://www.gigabyte.com/...70-Gaming-K7-rev-10#kfHAF-X Coolermaster: 4 Fans New Rig:Ryzen 1700 CPU-H100i Liquid arctic Cooled. 16gigs Corsair Vengeance DDR4-2400 180Ti Hybrid Blu-ray drive SCSI CDRW-RW drive SCSI Black WD Black caviar 2-1TB's and 1 500gig WD Blue 1 TB 1 Sand disk SSD 240 for OS Corsair PSU 1020 SWTOR Mouse and Headset Razer CHROMA Keyboard Dell 1444p G-Sync Monitor @144htz to 160htz
TheWizardMan
Re: How man 1080Ti owners Plan to Mod their Ti's with Air and Water Blocks?
2017/03/24 11:08:19
How do you know the EVGA blocks will be released next month? I'm not holding my breath.
| Asus Maximus IX Formula | Intel 6700K @ 4.8GHz | EVGA 1080 Ti w/ EKWB WBs (x2) | Phanteks Luxe TG | Custom Loop | | 32GB G.Skill Trident Z 3733 MHz | Samsung 960 EVO 500 GB M.2 Drive | Samsung 850 EVO 1 TB SSD | Cablemods Sleeved Cable Kit |
TRClark911
2017/03/24 11:16:55
I looked at the videos of those who have already done it and while I am definitely wanting to add a water cooler to the Ti I'm gonna wait till they are released.
notfordman
- Ribbons : 28
2017/03/24 11:25:23
warrior10 It seems these days with the Internet getting so much bigger with even more information about how to Mod Gpu's with better Air and Water cooling, it seems almost to be the Norm now. Next month i will be getting the EVGA Water block myself.
Woah, do you have any info? Link? I am going EK Titan XP block, already have the block and plate. Waiting oh so patiently for step-up to get to me.
warrior10
2017/03/24 13:28:54
TheWizardMan How do you know the EVGA blocks will be released next month? I'm not holding my breath.
I don't know anything about when or if they will be releasing. That's why i asked how many people here will be Modding their 1080Ti's with Air and Watercooling from different sources/companies. :)
warrior10
2017/03/24 13:32:32
notfordman
Whoa Whoa, I Do Need to clarify, forgive me if i seem to have mis-represented Evga and others here, very sorry about that. What i was talking about is me getting a Water-block next month or this month from the Evga store that is for similar Gpu's or Amazon.com com, very sorry. I just put up this thread to see how many people would be Modding their 1080Ti FE editions with special Air and Water cooling blocks.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2017/03/24 19:52:57
*raises hands* ME.. EKWB Titan X Pascal blocks on the 1080ti Founders Edition card.
rla1999
2017/03/24 20:03:07
Not me. I never mess with that stuff. I already like how its performing with no upgrades or overclocks. Good GPU for 1440p.
Chassis: Cooler Master HAF X (Blue Edition) CPU: I7 5930K MB: Gigabyte X99 Gaming G1 RAM: 64GB's Corsair Vengeance LPX DDR4 2666MHz GPU: GTX 1080 TI FE PSU: 1000W Rosewill Extreme SSD: 480GB Kingston HyperX SATA III 6GB/s HDD: 2TB Seagate Barracuda + 4TB Western Digital MONITOR: Acer Predator XB271HU OS: Windows 10, Version 1607 [/
strato79
2017/03/24 20:15:09
EK Titan XP water block and Ti FE sitting at the house waiting for outfitting when I get off work. 4th water cooled GPU for me so it's becoming a no brainer to go water on all my future CPU's and GPU's. Once you get the initial components for water cooling installed(rads, fans, coppression fittings, tubing, pump) it is fairly cheap to keep upgrades on water since you really just have to change the blocks. And if you sell you old ones at the right time, it's almost a no cost and a little time venture to keep everything on water.
notfordman
- Ribbons : 28
2017/03/24 21:06:09
Scarlet-Tech *raises hands* ME.. EKWB Titan X Pascal blocks on the 1080ti Founders Edition card.
She's a beauty! What do you have going on, on the bottom rad fitting, rear T? Can't quite make it out. Is that a drain for the loop? Noice! @Strato, very good point, once you have main components for loop. I hope you enjoy the heck out of your card /system.
post edited by notfordman - 2017/03/24 21:08:21
the_Scarlet_one
- Ribbons : 79
2017/03/24 21:45:05
notfordman She's a beauty! What do you have going on, on the bottom rad fitting, rear T? Can't quite make it out. Is that a drain for the loop? Noice!
Yep, that is the drain valve, since it is the lowest point in the loop.
strato79
2017/03/24 21:56:43
Have my system in the giant of all cases, the Phanteks Enthoo Primo. It has so much room it makes water cooling very easy and clean looking. Though mine still doesn't come close to how clean Scarlet's looks. Cable management is killer in mine but my tubing isn't near as nice. I just used UV blue flexible tubing with a couple of black lights to light it all up but they are dangling around with a lot of slack so I can pull my bay reservoir out easily to fill it.
And I do think that bottom T on Scarlet's is a quick disconnect for draining. I have a very similar setup for draining but mine doesn't have the disconnect. Mine is just a short piece of tubing connected to one of the bottom ports of my bottom UT60 Rad with a turn valve at the end. So I just put the end out it in a bucket and open the valve after taking off the fill port plug from my reservoir to release the pressure. When not in use, it's tucked neatly behind the bottom rad so you don't see it. I have a EX480 Rad up top with 8 1200RPM Scythe Gentle Typhoons in push/pull. The bottom UT60 has 4 of the same in push/pull. I'm still jealous of how neat Scarlet's tubing is though.
the1320god68
2017/03/24 23:28:02
EK Titan x waterblocks and back plates. No complaints here.
Muromets
2017/03/25 00:50:14
Nice looking build! What temps are you getting on the cards under load? And how much rad space cools your cards + motherboard? (6.120?)
ASUS RIVE | i7 3930K @ 4.6GHz | 2 x EVGA 1080Ti FE | AGON 35" G-Sync 3440x1440 @100Hz | G.SKILL 32Gb @2133MHz | Rosewill THOR V2 | Corsair AZ1500i | H2O 7.120 loop XSPC/EK | Logitech G19
the_Scarlet_one
- Ribbons : 79
2017/03/25 06:38:38
Muromets
I have seen the temps get as high as 45c after shutting the doors and letting the room become a sauna... regretted that right away. On the gpu, motherboard chipset, and motherboard VRM I have two 480mm radiators and one 360mm radiator. On the CPU loop, I have two 480mm radiators.
rlb9682
- Ribbons : 11
2017/03/25 07:09:45
I'm putting my TI under water...when the parts finally get here. The 1080 TI is arriving today but the water block doesn't get here until Monday :( And what the! Scarlet! Do you think you have enough radiators??? :)
post edited by rlb9682 - 2017/03/25 09:49:52
Affiliate Code: PD1HHD50JK
famich
2017/03/26 06:30:12
1080TI FE here with Hybrod AIO kit of 1080 - runs perfectly. Temps max 39 C .
INTEL 12900KS at 5700, allcore 5450 GSKILL 4000 DDR32Gb ASUS STRIX Z690 DR4 ASUS RTX 3090 OC STRIX LianLi
- Ribbons : 282
2017/03/26 11:25:37
famich 1080TI FE here with Hybrod AIO kit of 1080 - runs perfectly. Temps max 39 C .
Please Post a Photo !!!! Or Two
shadowboricua
2017/03/26 11:45:38
I am debating buying the EVGA hybrid cooler vs EK/Phantek Waterblocks... definitely cheaper to go with Hybrids. Waiting for my 2nd Ti to arrive and then I'll make a decision.
warrior10
2017/03/26 11:54:14
I thought you would since you know all the TOS rules about Air and Water cooling and have said you have done it before. These lights that look like Christmas lights are sure an awesome illusion. I'd love to have the same colors, with exception to them all being just Christmas colors. You will of course give us your results right, heheh.
warrior10
2017/03/26 11:58:26
We do need some good photos; we're all Tech fans after all. I have heard that the AIO and the Evga could have the 1080Ti's in the high 40's, but it takes a lot of Coolers and ventilation of course, and that is under really no big Gpu stress testing. More the rare i'd think.
meizme
2017/03/27 14:58:02
Fabulous! Scarlet-Tech *raises hands* ME.. EKWB Titan X Pascal blocks on the 1080ti Founders Edition card.
Operating System: - Windows 10 x64 Pro - Custom Lite Edition - Build 1703 Display: - LG 34UM95 21:9 ultrawide (3440*1440) CPU: - Intel Core I7-3770k @ 4.45Ghz 0.95v Motherboard: - Asus maximus V extreme Videocards: - [2x] EVGA GeForce GTX 1080 Ti FE Video Cards in SLI Memory: - G.SKILL TridentX Series 16GB DDR3 @2400Mhz Power Supply: - OCZ 1250w ZX PSU Cooling: - [3x] Akasa 140mm Viper PWM Fans (radiator) & [8x] ML140 140mm PWM Magnetic Levitation (Case) - Magicool Extreme Triple 140mm Radiator & Swiftech Apogee GTZ CPU Waterblock Drives: - [1x] HYPER M.2 X4 PCIe - 256Gb 950 Pro - [1x] 3Tb & [3x] 1Tb 7200rpm HDDs - [2x] 256Gb & [1x] 500Gb SSDs
Heini2
2017/03/27 16:13:22
I could only wish EVGA would let me buy an ICX cooler for a 1080 Ti!
Z170 Sabertooth Mk1 / i7-6700K + NH-D15 / Trident Z (2x16GB)@3000 / 2080Ti XC Ultra / Essence STX II / 950 Pro 512GB / G3 1000W / MG279Q / HAF XB EVO / Win10 X64 Pro
