Xantac
Parts list Case : Meshify C – Dark TG Purchased Processor:? Motherboard:? PSU: 850 bronze Purchased SSD: Mushkin 120GB Chronos (Thank you notfordman) "free" HDD:Some WD 1 TB drive "free"
post edited by Xantac - 2018/05/01 06:39:58
- Rig 1: Rampage5/w 6850K g.skill 3200 cas15 16gb, High-speed PC HPTX Bench w/ GTX 980
- Rig 2: RIVE/3930k /w Koolance mobo/cpu blocks/16gb 2133 c9, EVGA 1080 Ti Sli EK Nickel Blocks & a 78MH/s Eth
- Rig 3: asus rog crosshair vii hero (wi-fi)/2600x, g.skill 3200 cas15 16gb, gt 730
- Acer Predator Monitor
- Xantac's Heatware
fearpoint
Re: Hi friends, I'm about to build my mother a pc but need HELP, will be my first ryzen bu
2018/04/29 15:44:52
Do you hate your mom? Why would you force AMD on her like that.... Does Mom need good front panel airflow? If not forget the mesh it's gonna get dirty fast. If I were you, I'd get her an Intel NUC.
Xantac
2018/04/29 16:00:17
AMD finally got good(better) and I want to have one in the house. I just didn't know which processor to pic. I guess it depends on the motherboards if it overclocks , and new with the x450's and x470 coming out I'm getting more confused on mobo's AMD side . I don't even know what the heck a NUC is. And I have several cases at my house and that's the one she wants, so be it..... Nothing wrong with good airflow and cleaning the front panel more often, I have a electric blower anyway. I just want her to get what she wants.
- Xantac's Heatware
Nereus
Captain Goodvibes
- Ribbons : 58
2018/04/29 16:19:48
Is your mom a gamer or a graphic artist or big on video editing? What does she intend to use it for? Do you have a monitor for her to use already or are you buying one? What is your budget for this? Btw, a NUC (Next Unit of Computing) is a very compact PC. Intel NUC. Amazon NUC.
Xantac
2018/04/29 16:23:03
99.99$ AMD RYZEN 3 2200G Quad-Core 3.5 GHz (3.7 GHz Turbo) Socket AM4 65W 163$ AMD RYZEN 5 2400G Quad-Core 3.6 GHz (3.9 GHz Turbo) Socket AM4 65W (4 Cores / 8 Threads Unlocked?) Is the 2200g mainly for overclockers? like ryzen 1300, 1700
- Xantac's Heatware
- Ribbons : 115
2018/04/29 16:32:13
Moved to General Hardware.
Bruno747
- Location: Looking on google to see what Nvidia is going to o
- Ribbons : 5
2018/04/29 19:59:38
☄ Helpfulby Xantac 2018/05/01 06:22:09
Id say give it a few weeks and pickup one of the original ryzen 4 or 6 core chips on the cheap since they are now replaced with the 2000 series.
X399 Designare EX, Threadripper 1950x, Overkill Water 560mm dual pass radiator. Heatkiller IV Block Dual 960 EVO 500gb Raid 0 bootable, Quad Channel 64gb DDR4 @ 2933/15-16-16-31, RTX 3090 FTW3 Ultra, Corsair RM850x, Tower 900
Xantac
2018/05/01 06:36:21
Bruno747 Id say give it a few weeks and pickup one of the original ryzen 4 or 6 core chips on the cheap since they are now replaced with the 2000 series.
that's the plan kinda trying to purchase 1 item a month(have half of them) to broke to buy a complete system :) On the other hand it looks like as far as the new ryzen2s go the 2600 is the best if you supply your own display output, 200$ is pushing it out though. So on motherboards x370 just add crossfire and maybe a m.2 and couple sata's? B350 is fine for overclocking? memory speeds a little faster on the x470... Also I have a 32GB g skill memory kit, can I add 1 or 2 of those off my working x299 and possibly get them to work on the ryzen board?
post edited by Xantac - 2018/05/01 06:38:57
- Xantac's Heatware
