Re: Help with evga overclocking thing
2018/09/23 07:32:28
Hi,
Best way I've found is to lower the core clock to 2025 or so and increase the memory till you get fragments.
After you get fragments dial it down till they disappear.
Then raise the core clock until it gets unstable and dial it down till it's back to stable.
Run some benchmarks time spy/ fire strike even final fantasy XV is a good all around benchmark test.
Then test in an actual game once you've dialed in from benchmarks.
My first build,Case 450D/ ASUS Sabertooth X99/ 5930k with EK mono block / Water loop EK 280p-GTX240 radiators with D5 pump res combo before rads and D5 top after / Trident-Z 3200C14 4x8gb/ EVGA 1000 P2/ EVGA 1080ti FTW3 with EK copper water block. 2nd build,Case D450/ ASUS x299 Prime Deluxe/ i9-7900x delidded with EK mono block/ Trident-Z 3600C16 4x8gb/ Water loop EK-280p-GTX240 radiators with D5 pump-res combo before rads and D5 top after/ EVGA 1200 P2 / Titan Xp with EK water block.
