Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler
on1yalad
2015/08/06 11:31:40 (permalink)
Having a mounting problem not sure if it is something i did or if one of the products is not compatible/manufactured differently
I Stepped-Up to a 980ti ACX 2.0+
I Bought a Evga Reference Cooler
I bought Hybrid Kit + Backplate
Removed the ACX cooler
Removed the Heat Spreader MMCP
Cleaned the GPU DIE
Applied thermal Pads
Installed the Reference cooler - Fit perfectly
tried to install the hybrid water block - Problem
Things i checked with the water block.
  • Interference - the copper core of the hybrid water block was flush on top of the GPU DIE.
  • Pillar holes matched the PCB and reference cooler
The problem seems to  be that either the GPU Heatsink Spring screws used on the ACX 2.0 are shorter than the reference boards screws, or the hybrid waterblock mount pillars are not long enough.
Someone else said they removed the springs from the screws and carefully tighten them and put locktight i am a bit scared to do this.
options
1. Remove the springs on the screws and carefully tighten.
2. Find longer screws - this doesn't seem possible as i have been look for 6 or so hours to find 10mm length screws with springs that would fit.
3. Get a different type of screw - http://www.frozencpu.com/products/17729/scr-360/3mm_VGA_Graphics_Card_Spring_Loaded_Screws_-_2_Part.html?tl=g55c513s1810 - not sure if this would even work.
Anyone have any suggestions or experience with similar issues.
Intel i7 5820K @ 4.6GHz, 32GB G-Skill RipJaws 4@ 2400MHz, 2x EVGA 980ti w/ AIO Hybrid cooler, EVGA x99 Classified, 4x Intel 730 SSD 480GB, 2x HGST 3TB, NZXT Kraken X61, Dell U3415W 21:9, BenQ XL2420TX, Windows 10 Pro, CM Carbide Air 540, EVGA Supernova 1000P2
18 Replies Related Threads
    pureallstar3482
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:33:30 (permalink)
    I may be wrong...but if I'm not mistaken, the ACX is not a reference card. Hence they layout will be different. You have to buy a reference card in order for the bracket and cooler to fit. To my knowledge (again, I could be wrong), but the ACX card is a non-reference card, thus, has a custom layout designed by EVGA.
    CoercionShaman
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:36:32 (permalink)
    Correct to an extent.  The real problem lies in the base plate on the ACX and the fact that there is not a blower fan on the ACX either.  You have to have that reference style blower fan to cool every other component besides the GPU.  Did you get the entire assembly with the new cooler you bought?
    What use is knowledge if there is no understanding?~Stobaeus
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:39:23 (permalink)
    pureallstar3482
    980ti ACX 2.0 cards are on reference PCBs only difference is the cooler - i could be wrong but this is based on my talks with support and also the available info about the PCB itself.
    Where did you read this? My understanding is that only the Classified / Kingpin cards from EVGA have custom PCBs
    CoercionShaman
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:40:50 (permalink)
    They are the same PCB on the ACX as the reference.  That is why you can buy an ACX cooler and apply it to a reference card.
    pureallstar3482
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:41:50 (permalink)
    Again, I wasn't entirely sure. Looking around, it is, in fact, a reference PCB. As long as you have the reference style blower (instead of a push pull fan, it discharges through the back of the card) the bracket and cooler should fit.
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:42:09 (permalink)
    CoercionShaman
    This is what i bought which was off an evga Reference 980ti
    http://i.imgur.com/PKkMdvh.jpg
    http://i.imgur.com/DOh1jfq.jpg
    i replaced all the Thermal Pads TIMs with http://www.performance-pc...s-200-x-150-x-1-0.html
    CoercionShaman
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 11:47:00 (permalink)
    Looks like you got the base plate with it.  Reading back through the OP, you may be right on the screws.  If you didn't get the screws with it as well, I don't know that the ACX screws will fit.  Is the base plate on the ACX the same measure of thickness?  Did you measure the length of the posts?
    EDIT:  Just saw you changed the thermal pads.  I'm not sure what the thickness is on the original pads.  I remember an EVGA tech answering that, but can't find the thread right away.  Are they the same thickness?
    post edited by CoercionShaman - 2015/08/06 11:59:48
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 12:00:52 (permalink)
    i will see if i can i find my caliper and measure the posts. i really don't want to pull my retail hybrid 980ti apart  but i may have to.
    do you think EVGA would send me some screws if that was the problem?
    CoercionShaman
    1mm was suggested by Evga support, and those were what i bought
    CoercionShaman
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 12:06:07 (permalink)
    on1yalad
    CoercionShaman
    I meant to ask if the posts on the ACX where the same length as the AIO kit.  I guess it is possible that the AIO you received is a different length than any other AIO, but that seems highly unlikely.
    You could always ask about the screws.  I have no idea.
    Good deal on the pads.  Thought I'd ask since it was a variable.
    EDIT:  I ask because the ACX kit comes with screws that truly could be different http://www.evga.com/Products/Product.aspx?pn=100-FS-2990-B9
    post edited by CoercionShaman - 2015/08/06 12:29:58
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 12:23:43 (permalink)
    Do you or anyone else know of anywhere i could find replacement screws. or the exact dimensions of the screws needed?
    i don't even know the specifics of which ones to get. - not sure if these are correct.
    http://catalog.pemnet.com...-spring-types-scb-scbj - looks like this is a CAD element and not a physical screw.
    post edited by on1yalad - 2015/08/06 13:38:32
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 14:25:48 (permalink)
    Talked to Support.
    They said their shouldn't be any difference between ACX heatsink screws and reference screws, but they will be sending out a screw pack for good measure.
    if not them i think i need to find a longer m3(length 10-12mm) screw just not sure of the the thread, any suggestions are welcome if the screw pack doesn't work.
    EVGATech_ChrisB
    EVGA Tech Support
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 15:43:19 (permalink)
    Dear on1yalad,
    I can confirm that your request for these screws is processing and that the reference screws can be a little longer than the ACX screws so this should fix your install issue.  Please do not hesitate to let me know if you should need more help. chrisb@evga.com
    on1yalad
    Talked to Support.
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 16:44:01 (permalink)
    EVGATech_ChrisB
    Dear on1yalad,
    on1yalad
    Talked to Support.
    Thanks again Chris and Brandon for the help. i know it wasn't required as this was kinda out of scope of the products but the support is why i buy/recommend EVGA and their products wherever i can.
    ill update the thread once i get the screw package and get the card installed.
    Reaper_7799
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/06 17:04:55 (permalink)
    Yeah, the support for out of the box thinking like this and allowing you to do it is great with evga.  They always seem to help too if they can.  Glad you got it sorted.
    I7-4790K-- 4.7GHz l EVGA GTX 980 TI HYBRID-- 1502 MHz l Asus H97 Pro Gamer l Avexir 8GB LED l Toshiba Q Pro 128 GB SSD, WD Blue 1 TB HDD l XFX Core Pro 750 W l Phanteks Enthoo Pro l 4K Surround @ 75 Hz---2 Acer and one Asus l 2016 Samsung 40" 4K
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/13 10:12:25 (permalink)
    Wanted to share an update.
    So i received the screws and unfortunately they are exactly the same. i compared them to my retail hybrid 980ti and they seem to be 2mm longer. What i decided to do was to soft washer the screws without the spring and seems to work fine.
    i tried it with the pre-applied thermal compound and it was about 3c lower than my retail hybrid, but i needed to make an adjustment which i had forgot to do before hand and so i spend the next 3 hours cleaning -> repasting -> installing -> testing  to see where my temps were.
    unfortunately the results were no where near the pre-applied thermal compound. usually it was about 8c warmer than preapplied and 5-6c above the retail hybrid 980ti. i finally decided to use a smaller amount than what most users were suggesting, as i remember that smaller amounts were better cause it was thinner and less air and that did it. i am about 1-2c higher than the retail card, and im okay with that.
    i have noticed that i cant get over 1300mhz on this card i don't know if that is a bios problem due to the temp/voltage table as it is a SC ACX bios. i know support has said that best not to mess with the bios. but if the cards are both ~72+ ASIC and same temps couldn't i flash the stock hybrid bios on the SC AC card? (obliviously backing up the stock on the ACX card.)
    CoercionShaman
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/13 10:25:59 (permalink)
    Excellent that you found a working solution on the mount.
    Not sure what if any difference there is different in the bios.  I thought the voltage table was the same across the series save the custom PCB boards.
    Could you flash it over from a hybrid?  Sure.  Could you brick it?  Sure.  I guess that comes down to whether or not you feel it will give you a change you are looking for.   That card just may not be capable of doing more.
    on1yalad
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/08/13 10:48:25 (permalink)
    The power tables are the same but the boost tables are shifted i think due to the expected heat from an Air cooler vs a water AIO. i am not trying to get on crazy overclocks but my stock retail hybrid hits 1450mhz stable and the SLI combo is 1304Mhz limited by the ACX card.
    Also it would fix the annpoying thing where the fans are not sync'd so i have to keep AB or Precision open other wise the PCB fan shuts off due to the retail hybrid base line 20% = 0% on the ACX card.
    http://imgur.com/Hg3YOqs
    mangus123
    Re: Help: EVGA 980ti ACX 2.0 to Hybrid + Reference Cooler 2015/11/24 16:55:39 (permalink)
    I did this exact same thing... Went from a 980 ti acx 2.0 to EVGA hybrid cooling it. I found a reference blower and mounted it with longer screws (m2.5 8mm if I'm remembering correctly). I had it all assembled and it looked great but got like 80 degrees when just at idle so clearly the water block was not in full contact with the GPU. The mid plate seems to be too high above the GPU to allow full contact. Did you end up having to use a copper shim because it looks like I'm going to have to which is fine I'm just curious. If not then maybe I'm mounting it incorrectly which seems unlikely since it's pretty straight forward and I'm not a dummy but I guess you never know. xD Thanks
    post edited by mangus123 - 2015/11/24 17:03:18
