dwoodward
You did reboot after running nvflash right?
yep, even tried with a complete shutdown after the flash.. didnt change anything. look like it isnt actually flashing the bios. I am quite lost at this point of time and RMA doesnt look like an option to me. A friend has the exactly same card, i asked for him to save his vbios and send it to me to flash... didnt work either.
I found a comand in nvflash to restore a local copy of infoROM, would that make any change?
according to the nvflash is valid...
C:\nvflash>nvflash64.exe --recoverinforom
NVIDIA Firmware Update Utility (Version 5.715.0)
Copyright (C) 1993-2021, NVIDIA Corporation. All rights reserved.
Reading VBIOS image for recovering inforom....
The existing InfoROM image is valid. Restoring the InfoROM from
the embedded recovery image may cause some data loss.
Are you sure you want to continue?
Press 'y' to confirm (any other key to abort): n
ERROR: User aborted!
C:\nvflash>
but... upon comparing the vbios in the card vs. the rom ive downloaded..
C:\nvflash>nvflash64.exe --compare RTX3070TI-EVGA-ICX-Stock-Working.rom
NVIDIA Firmware Comparison
Comparing RTX3070TI-EVGA-ICX-Stock-Working.rom...
Current - Version:94.04.5A.00.FA ID:10DE:2482:3842:3785
GPU Board (Normal Board)
Compare with - Version:94.04.5A.00.FA ID:10DE:2482:3842:3785
ERROR: Size difference between file(0xEAE00) and adapter ROM space (0x1F6E00)
NOTE: Make sure to compare with entire saved image file.
Primary Firmware Image
Legacy BIOS ........................................ Pass
UEFI ............................................... Pass
Firmware Certificate ............................... N/A
InfoROM ................................................ Mismatch
Static ............................................. Mismatch
Unallocated Space ...................................... Mismatch
Mismatch Details
- Data
Static
InfoROM Header - Timestamp
MISMATCH ERROR: Command Compare error
C:\nvflash>
post edited by mpmtechmine - 2021/12/08 06:29:09
