pplshero54
How did you build it? What's it like?
STR1D3R_2
- Ribbons : 13
Re: Has anyone build their own desk for their battlestation?
2020/12/26 16:00:39
Yes tape measure, pencil, framing square, level, wood, saws, router, biscuit joiner, screws, gorilla glue, sanders, stain,shellac Comfy
post edited by STR1D3R_2 - 2020/12/26 16:14:04
Affiliate code E1HEL4HYPS
pplshero54
2020/12/26 17:27:11
Nice. How long did it take?
STR1D3R_2
- Ribbons : 13
2021/01/02 14:52:55
Sorry for the delay, built in about 4 hours. Sanded about another 2 hours. Then multiple clear coating with light sanding in between. each additional coat was about an hour with 24 hrs between. I used oak and mahogany
rsxownes
2021/01/06 15:00:47
just built one for under $100 getting stuff from IKEA. 5 table legs, and 98 inch kitchen countertop. Going to add another ~70 inch section to make it L-desk. But so far it is a vast improvement to what I had looks wise and organization.
Current RIGCase: Phanteks Enthoo Primo black case CPU: Intel I9-13900K MB: ASUS ROG MAXIMUS Z790 HERO RAM: G.SKILL Trident Z5 RGB Series 32GB DDR5 5600 PS: EVGA 80 PLUS Platinum 1000 W SSD: Kingston KC3000 4TB PCIe 4.0 x4 NVMe GPU: Nvidia 4090 Heatware: https://heatware.com/eval.php?id=100702
biz1
2021/01/06 17:29:35
My wife and I are looking at getting a wood or butcher block counter top from Lowes or Home Depot and then buying a few legs. Might end up doing it soon since we've been fortunate enough to be able to work from home for months.
Athian
2021/01/07 21:24:00
biz1 My wife and I are looking at getting a wood or butcher block counter top from Lowes or Home Depot and then buying a few legs. Might end up doing it soon since we've been fortunate enough to be able to work from home for months.
I did what you are thinking of doing. I bought my butcher block top at Lowes and used these legs for it since they are rated at 300lbs per leg. Works great. I bought the 4-foot butcher block. 28" Tall Desk Legs Matte Black
post edited by Athian - 2021/01/07 21:35:24
biz1
2021/01/08 09:31:04
I did what you are thinking of doing. I bought my butcher block top at Lowes and used these legs for it since they are rated at 300lbs per leg. Works great. I bought the 4-foot butcher block. 28" Tall Desk Legs Matte BlackNice work. It looks great. I like your set up. Looks much more tidy than my work/gaming space.
Athian
2021/01/08 14:11:03
biz1 Nice work. It looks great. I like your set up. Looks much more tidy than my work/gaming space.
I need to clean up the cables behind my pc, but I wanted a very clean setup. Another suggestion if you want something inexpensive. A solid core door works as well if you want to do a longer desk or 2 setups on 1 desk.
Joshdb2010
2021/02/27 07:14:09
Here is my setup. I bought 2 10' butcher block tops from HD. I took one and made a 45degree cut in it and flipped one side over and joined & glued it to make the corner section. Then stained and finished the top. I went with some Ikea legs and it is pretty solid. Now just to get my graphics card and peripherals to finish my build. I'm hoping to get a Samsung odyssey G9 that will go in the corner (if it even fits)
biz1
2021/02/27 09:11:44
Joshdb2010 Here is my setup. I bought 2 10' butcher block tops from HD. I took one and made a 45degree cut in it and flipped one side over and joined & glued it to make the corner section. Then stained and finished the top. I went with some Ikea legs and it is pretty solid. Now just to get my graphics card and peripherals to finish my build. I'm hoping to get a Samsung odyssey G9 that will go in the corner (if it even fits)
Nice job!
Joshdb2010
2021/02/27 09:20:37
biz1
Nice job!
Thanks! I needed all the space I could get for the laser projects and stuff. Ikea sells some cabinets that are the same heights as these legs so I might add a couple of those after I get the pc built and start using it.
biz1
2021/02/27 09:34:31
CB2 also has some small file cabinets that could fit under there. I bought some for the home office/spare bedroom.
